mayday~!!!!
Old May 23, 2006
jacky599r's Avatar
jacky599r is an unknown quantity at this point
mayday~!!!!
ok. i was feeling kinda high. so i decided to drag my car along the street. it was midnight. so yeah. ok ....... HERE COMES THE ****. when stopped at a traffic light.... my car simply will not idle! it shoots up to4k and holds it there. and down again. up and down again. when i engage a gear and slip the clutch it. it was ok. but rough. when i went into neutral it has the same prob again. switching off and on doesnt help. so what now man! im on e manage ultimate. jesus! help!!!!
no cel
Old May 23, 2006
v8eaterokv6's Avatar
i have a new home do u
with out the e manage on there i would say tps do you have any engine codes that will tell you whats up
Old May 23, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
vac leak?
Old May 23, 2006
jacky599r's Avatar
i have the emanage ultimate. so yeah. anything wrong with that? how come there is a sudden failure>
Old May 23, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
is it tuned or just with a base map?
Old May 23, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
do you have a missing link?
Old May 23, 2006
jacky599r's Avatar
tuned.(i have a post with dyno graph... was supposed to put up my AFR but guess not at the moment) i dont have a missing link. there is no check engine light or whatsoever. ot was still fine this afternoon and just now.... until the fateful stop at the junction. it just shot up i was like shockedand thought i had the brakes as throttle. help help help?!!!!!!!!!
Old May 23, 2006
you should post a link to your dyno so someone can help you out better
Old May 23, 2006
jacky599r's Avatar
assistance?????
Old May 23, 2006
yeah
Old May 23, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Off topic, but what kind of Intake Manifold do you have jacky
Old May 23, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
dirty iacv or tps.
Old May 23, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
^^ whats "iacv"
Old May 23, 2006
stinkypie's Avatar
A big, hairy Kentucky boy
stinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to all
Originally Posted by 02BLKCIVIC
^^ whats "iacv"
I believe that's an Idle Air Control Valve.
Old May 23, 2006
02BLKCIVIC's Avatar
Hmm^ thanks!
Old May 23, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
have you tried to reset the ecu by unpluggin the battery for a minute of 2 them connecting it back then let the car idle for 15minutes or so..???
Old May 24, 2006
HyaBoosta's Avatar
Is your vac. still at the same level on your boost gauge or does it change with the idle? Look for a off vac. line or check the TB. May need to be cleaned.
Old May 24, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Did you reset the ECU?
Old May 24, 2006
jacky599r's Avatar
ok thanks guys. it turned out to be a vac leak......
hose to the actuator was off. so was the hose connecting to the intake mani. i spend 50 bucks on towing the car and 3 mins to get the car going. i learned something nontheless. thanks for the help
