7thgen with k20 swaps
Old Apr 27, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
hmmm... just outta curiosity... if i became an online vender once again.... and made custom cold air intakes with a velocity stack for around the $150 shippedprice range... probably cheaper... who would be interested???.. i finally got a wholesaler to make these custom intakes now... i could even do one for the good ole d17.... but its just a thought and kinda in process right now... i'll have a mockup of it and pics taken probably in the next few days
Old Apr 27, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
What about those in cali *me excluded lol* you going to get them carb legal .
Old Apr 27, 2006
i talked to someone about that earlier today.. so im supposed to be getting some paperwork with some info on it but i cant say for sure yet...
lol.. what swap is carb legal anyways.. ....j/k
Old Apr 27, 2006
kezay's Avatar
kezay is an unknown quantity at this point
that could be a good idea
Old Apr 27, 2006
HondaLuver's Avatar
Its a celebration bitches!
my swap is carb legal...
Old Apr 27, 2006
yea and i only paid $19.99 for my smog check..... each state has a different term for it.. anyways i might have a pic later today.... i got the day off so i got time
Old Apr 27, 2006
02cvcEX's Avatar
02cvcEX will become famous soon enough02cvcEX will become famous soon enough
this is prob a noob question but what's a velocity stack?
Old Apr 27, 2006
Last edited by xproductionz; Apr 27, 2006 at 12:31 PM. Reason: Automerged Doublepost
Old Apr 27, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
Do Those Come With Filters In Them???
Old Apr 27, 2006
well i am working on a version that attacches to the filter.. the kit once complete will come with all piping, filter, and velocity stack.. so you can run it one of 3 ways..
1. straight intake pipe with velocity stack
2. straight filter
3. filter with the velocity stack attached to it..
i'll have pics with examples in a day or 2..
Old Apr 27, 2006
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
My swap in my civic is alost done and if you made the velocity stack and piping in carbon fiber I would jump all over that...lol
Old Apr 27, 2006
whitevic's Avatar
whitevic is an unknown quantity at this point
What sort of stacks are these? Are they comparable to the ones Shawn Hiller is selling? What size in/out?
Old Apr 27, 2006
velocity stacks are the bomb. I was down tunning my car last month and just for one we strapped one to a b18 high compression Del sol on the dyno, picked up 10hp! lol. Maybe i should get one of these for the track.. think you can make one that will replace a head light?
Old Apr 28, 2006
well... finally got in the velocity stack today...
dimensions are
inside diameter - 3in
outer diameter - 6.5in
height - 2.5in
This first pic is to give u an idea of the actual size
fyi:... the materials that will be used to make this intake are polymer based in combination with chromium plating that both insulates and reflects heat unlike those steel, aluminum and titanium intakes that are commonly found so that way the intake components stay cooler and deliver more cold air power to your engine.
Last edited by xproductionz; Apr 28, 2006 at 02:42 AM. Reason: Automerged Doublepost
Old Apr 28, 2006
whitevic's Avatar
I would personally rather have an aluminum one welded on, for a cleaner look. I would much rather deal with a filter and clamp, instead of three clamps, a coupler and a filter.
Good luck though!
Old Apr 28, 2006
Good luck though!
3 clamps and a coupler and filter????
if you run only the air horn you only need 1 clamp... if you only run the filter you use 1 clamp... if you use the filter and air horn you use 1 clamp and a coupler... where is the other 2 you are refering too??
Old Apr 28, 2006
whitevic's Avatar
I'm reffering to the one coupler that holds the stack to the intake tube, via two clamps, then the one clamp needed to hold the filter onto the stack. I wouldn't run without a filter, unless I was at the track.
Old Apr 28, 2006
the way im setting it up is a little diffferent...
wish i could post pics but give me some time and i'll have more pics up..
Old Apr 28, 2006
kezay's Avatar
Xproductions this is sounding good....
Old Apr 29, 2006
Im wondering how much of a differnce this would make on my SC?
Old Apr 29, 2006
i'll keep everyone updated
Old May 11, 2006
well... here is the 3 different configurations i am talking about
here is the intake with a straight basic filter setup
here is the filter with the velocity stack option but in front of the intake not in the back.
then here is the straight velocity stack attached to the intake...
im trying to do it where the kit will include all the pieces to do all setups.. so you could run the filter for daily then change it to the velocity stack for the tracks and probably use the filter/velocity stack option for street racing
Old May 11, 2006
I dont think this one would be very effective:
Reason being, you have a filter sucking in air, and the stack wouldnt channel the air in properly if you ask me. Just seam like it wouldnt work becuase the air would flow in the path of least resistance. Not to mention that then exstends the filter out and you would have to space the filter farther back.
Old May 11, 2006
well like i was saying you could if you wanted to... im not saying u have to if you dont want to.. after looking at the pieces of the mock-up kit i saw that it was possible to set it up that way.. so in hence if you wanted to you could... but the only 2 i am concerned about is the filter or velocity...
anyways i couldnt sleep so here are 2 more pics
Old Jul 18, 2006
Hey you have any of your v-stacks laying around? WOuld you sell one? how much?
Old Jul 19, 2006
HondaLuver's Avatar
last time i checked, the CAI doesn't go like that. lol
Old Jul 19, 2006
lol... let me take some pics to show u it on the car
Old Jul 19, 2006
You want to build me one with an oem headlight? Ie it routs from the TB, to the headlight/v-stack?
Old Jul 20, 2006
you mean taking a stock head light and making a hole in it and so forth??
Old Jul 21, 2006
yup!
