tsi people. when does your t25 start spooling, and build boost??
Old Apr 26, 2006
ncirom2003's Avatar
at what psi does it start to build boost?
today i kept my eye on the gauge and slowly raised rpm but it never even went to 0 out of vacuum. then from idle i floored it real quick (to 3k)and the needle was going to 0 but i never really saw it go past that.
Old Apr 26, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
With out load your turbo wont get into boost. Read - idle.
When moving I get full boost - 9psi/t25 @ 2500-2700 rpms.
Old Apr 26, 2006
ncirom2003's Avatar
so just sitting there revving it, not even at wide open throttle i shouldnt expect boost at like 3k?
ive never driven a car with a gauge so this is sumwhat new to me. and i thought this was correct but with a guy coming to tune my car i wanted to double check with you guys.
Old Apr 27, 2006
eye_see_you's Avatar
let the devil out
the t25 spools at about 2500 rpm and if your applying throttle
and if your not going above 0 psi then you have a pipe loose somewhere start checking them all
Old Apr 27, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
You need to load the engine for it to build boost. You can't make boost in neutral.
If its not building boost while moving, or building it very slowly, check to be sure the WG flapper is tight, and check all the couplers.
Old Apr 27, 2006
dezod's Avatar
7thgen Power Maker
You need load.
SO MANY PEOPLE THINK THEY DO NOT NEED LOAD TO MAKE BOOST, BUT THEY FORGET TURBOS ARE EXHAUST PULSE DEPENDENT. There are minimal pulses at neutral, all of the pulsing is made during load while driving.
Old Apr 27, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Thank god you dont need load for the BOV to work!
Old Apr 27, 2006
ncirom2003's Avatar
yea thanks guys, i found a pipe actually disconnected cus some guy at the shop thought it was hitting the crank so he moved it. its good now.
but the tuner tried tuning it and weve got fuel issues with emanage, id appreciate your help in that thread in FI.
Old Apr 27, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
I know you can't build boost without a load, but how does a 2-step work then?
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Aball93
May 16, 2015 10:11 AM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
black2k1vtec
Dec 6, 2001 09:49 PM
