Alright you motor heads.... I'M IN BUSINESS
Old Apr 18, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
The car was dynoed about 2 hours ago. It made no power. By no power, I mean 106.7 HP at 5693 RPM. It made 122.2 lb-ft at 3689. Now anyone who knows what a constant 6.1 PSI should do knows that SOMETHING IS NOT RIGHT.
The following have been ruled out...
Boost leak
Vac leak
heat soak
tuning (it just got tuned)
inlet restriction (only gains .8 HP w/o filter)
Pretty much leaves exhaust restriction. The shop guys say they've seen on WRXs that run too rich where the honeycomb in the cat fuses, and creates a big clog in the system... Given that the car has apparently been running about 9.6:1 for the last week, I could see this happening, but I'm open to any and all educated thoughts as to what I need to be looking for. The motor is quite healthy, no funny sounds, ticks, pings, etc..... and on the road, the enormous midrange is a friggen blast, but we all know shop guys included, the car's short at least 40 HP. SO WTF?
I'm on my way to work right now, I'll scan the HP, TQ and AF curves.
Old Apr 18, 2006
dezod's Avatar
7thgen Power Maker
The stock cat on there? Running a boost controller? Is boost tapering off?
Old Apr 18, 2006
Jap-Euro Fusion
yes stock cat... believed to be the issue. Going to take it off and look up there this weekend... may need to try out one of those snazzy Carsound OBDII cats. No BC, just the WG, the dyno logged boost at a very near constant 6 psi from 3000 to redline, no major dips or spikes.
The final numbers blanked out
the bottom line is 122.2 lb ft, 60 MPH, 3689
106.7 HP, 93 MPG, 5693 RPM
Other question is does that look like no VTEC to anyone?
Old Apr 18, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Look at my graph. The run include Magnaflow Cat and muffler silencer.
I have extremely massive bottom end. I think its due to not-so-high-flowing catalytic.
Thaaf dyno'd 170whp on his auto LX @ 7 psi (?) without cat.
With extremely similar set up, yes you're at least 60 whp short.
I'd definately try demo run w/o cat at all. At least you'll be able to see how much of a difference there is.
I'm getting test pipe, so I can see what it is w/o cat.
Old Apr 18, 2006
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
hmmm does it feel like 120 hp or does it feel like 170 hp cuz i'd say that if it isnt making any funny noises and theres no leaks or anything like that, i'd say the dyno is messed up.
Old Apr 18, 2006
dezod's Avatar
7thgen Power Maker
Experiment for bioler. Crawl under the car and undo the portion of pipe with the cat on it. Drive car and see if it feels more powerful. Open downpipe will rule out cat and exhaust restriction.
BTW carsound suck *** hardcore..............no wonder why they are so cheap.
Furthermore, do you have a boost gauge hooked up? Does it sit at 6 PSI?
Old Apr 18, 2006
Jap-Euro Fusion
yeah, I've got a boost gauge hooked up, and I have a WB A/F hooked up..... they both were in complete agreement with the ones hooked up to the dyno computer.
Saturday I'm going to rip some stuff apart. I'll try and run open DP.... gonna take it to someone's house in the boonies, and make sure I have a code deleter handy.
If you've got other suggestions for other high flows that are OBDII legal (as in its got an O2 sensor port).... then I'm listening.
Old Apr 18, 2006
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
sounds like a clog in the exhaust pipe or downpipe or something, because the torque number isn't that far off of what it should be, check restrictions I guess!
good luck man!
Old Apr 18, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
How long have you been driving around under boost with the stock cat?
Old Apr 18, 2006
Jap-Euro Fusion
Since last tuesday (1 week)
Old Apr 18, 2006
dezod's Avatar
7thgen Power Maker
Dumping fuel into a cat will cause failure VERY soon. A week of DD is more than enough to fry the brick.
I would say do a 2.25" or a 2.5" Random Tech cat. They are the best flowing, but no matter what if your throwing fuel into a cat, it will fail.
Old Apr 18, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
About your cat two ideas come to mind:
One:
Take the stock cat and gutted use a metal bar and chop at the insides till is all clean, leave nothing in there, nothing, wash it very good with a high pressure hose and make sure to remove the sensor first.
Then re- install it back on the car.
There will be no check engine light.
Even if this is not your problem, the car will run better.
Two:
Get an aftermarket cat then weld a bong for the 02 sensor on the pipe right after the cat.
I converted my LX to an EX type exhaust to accomodate a DC header back in 2001 when our Civic came out.
There was no check engine light afterwards and I had to cut and patch the wires cause I had to extend the harness, that was the only mod to my engine back then so I know it works.
other suggestions
Replace booth 02 sensors, your engine will run better.
Check your spark plugs.
Old Apr 18, 2006
Jap-Euro Fusion
The plugs are fine, we pulled them. The primary O2 sensor is new, as is the WB, the one in the cat is original.
If the O2 after the cat works, then the High flow is probably the most viable option.... it needs to at least be capable of passing a tail pipe test (it seems random whether they pull codes or actually pipe the car for emissions).... exploring all options, but I'm going to pull the cat off this weekend and look in it to see whats up.
At least everyone seems to be on the same page here, thats good that its not a random pile of crap to look at.
Old Apr 18, 2006
ncirom2003's Avatar
well an easy way to check for clogged cat, ive done it at work
start the car and let it get hot, then look down at the cat, if its red hot before it only its clogged. otherwise get a temp gauge (one that shoots infrared and reads, or touchit real quick) and check before and after cat, a difference will show a clogged cat.
Old Apr 18, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Have you tired just pulling your exsaust off and see it runs different?
Old Apr 18, 2006
TheSmuggler's Avatar
My votes for the cat being clogged. you said you were running pig rich, and on a stock cats thats supper clingy in the first place, I'm sure it got turned into a giant paperweight.
Old Apr 18, 2006
Havok2k1's Avatar
Wicked Pissah Admin
That curve is brutal. What were the a/f's like on the dyno?
Old Apr 18, 2006
Jap-Euro Fusion
It flutters between 11.25 and 11.5. Its not a bad AF, but it needs to be uncorked.
Right now its got a TQ curve like a volkswagen.
Old Apr 18, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
if ya need ne help boiler, dont hesitate to ask
oh btw, i know this is off topic, but are you coming to HIN?
Old Apr 18, 2006
Jap-Euro Fusion
I'm good to go with the extra hands, but thanks. As far as HIN, for the next few weeks, I'll probably be under the car, or in the office trying to pay for being under the car. I'm sure it'll need another tune job once the problem is fixed.
Old Apr 18, 2006
ncirom2003's Avatar
im tellin ya, its quick and easy. start the car let it run. check for excessive heat caused to built up backpressure caused by restriction.
Old Apr 18, 2006
Havok2k1's Avatar
Wicked Pissah Admin
If the cat doesn't check out, maybe try a leakdown. Have you done any valve / head work?
Old Apr 19, 2006
exturbo6's Avatar
yeah i had thr same problem when i had my turbo kit on...i went to get it dynod at 6lbs and i ended up making 108hp...i have the graph somewhere, and i checked everything and the shop did 2 and they couldnt find anything wrong with it..besides the point that i was running pig rich.
Old Apr 19, 2006
Jap-Euro Fusion
.... and so the problem was eventually found to be what? The cat?
Old Apr 19, 2006
I think he never found and and just took it off lol
Old Apr 19, 2006
exturbo6's Avatar
nope i just took the kit off cause then i start blowing fuses..
that is correct! im not going to waste money on something that isnt going to give me all that much anyways...so i took it off...you end up spend more money then its even worth for some BS gain..
now i have pently of money and looking for a car with potential...
Old Apr 19, 2006
Logan3024's Avatar
Boiler, Did are you sure that the dyno you used was accurate? You should be putting out ATLEAST 160-175 whp, 150-170 trq with the gt28r at 6 psi, probley more if you had a front mount.
If your cat is "clogged" than youll be putting out massive black smoke, from burning the unused fuel left in the exhaust.
GOOD LUCK!!! any CELS?
Old Apr 19, 2006
exturbo6's Avatar
i didnt have a cat on my car! striaght through! BTW.
Old Apr 19, 2006
Jap-Euro Fusion
no, no cels. We're gonna look at some fun stuff this weekend. I'm gonna pick up a high flow anyways, it'll make my life easier I guess. They say the dyno was accurate, and they put down a little over 170 w/ a stock WRX the day before, which IIRC is about right, so I don't think it crapped overnight, the car's performance on the road seems to match the graph, ginormous midrange, then sudden flatline at 4K. Something is wrong with the car itself, the curves don't even match the power band of the engine.
I'll get to the bottom of this, I always do.
Old Apr 19, 2006
Logan3024's Avatar
DAM! 106 flywheel hp? im thinking its the dyno! Go somewhere else to get it dynoed, if its different than 106 hp, ask the other place for a refund!
