question!! prolly a simple answer
Old Apr 18, 2006
collinshill26's Avatar
collinshill26 is an unknown quantity at this point
how can i have the stock oil pressure sensor, turbo oil feed line, and oil pressure gauge sensor set up at the same time?or can i?just asking because i know u can have 2 of those easily with a T fitting but can u have 3?
Old Apr 18, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Don't string T fittings together off the block its likely to snap off, get a distribution block and mount it to the firewall, or use a sandwich plate for the oil line.
Old Apr 18, 2006
thanks!!
i can plug 2 or three things in the sandwich plate right?
u suggest a sandwich plate?...i like how it works!!plus u can plug 2 or 3 lines or accessories in it
Last edited by collinshill26; Apr 18, 2006 at 10:58 PM. Reason: Automerged Doublepost
Old Apr 18, 2006
ncirom2003's Avatar
ill need a link to this "sandwhich plate"
Old Apr 19, 2006
tfnaaf's Avatar
BLDNPSI Mod
Here is mine, picture is large and a little blurry...
http://myweb.cableone.net/tfnaaf/images/DSC00190.JPG
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8054903899
Old Apr 19, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
i thought if you hook up your oil pressure guage you dont need to hook up your stock oil pressure sensor?, does it not replace it?
Old Apr 19, 2006
Jap-Euro Fusion
it DOES NOT replace it, you need them both to keep the ECU happy.
Old Apr 21, 2006
ah i see, so you tee it and hook up the sensor for your guage and the sensor for the ecu?
Old Apr 23, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
look at the sand. plate tfnaaf has in his post u just screw in ur sensors.
Old Apr 23, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
cool....i'm gonna need one of these
cukaracha
Aug 10, 2015 08:01 AM
Strycker
Aug 2, 2015 08:40 PM
spyder13
Jul 31, 2015 06:31 PM
breanna_17
Jul 21, 2015 04:01 PM
BootyDo
Jul 7, 2015 06:06 AM
