Swap Question
Old Apr 5, 2006
misterpho7's Avatar
misterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nice
Swap Question
Hey all, I been reading about swaps into the 7thgencivics, I know that since I have a 2005 Civic, I won't be able to put a K20A2 motor in, since its a older motor.. I was wondering if they made K20A motors in 05`.
Old Apr 5, 2006
my1vtec's Avatar
my1vtec is an unknown quantity at this point
you can put a k20z1 out of the 05-06 type s or the k20z3 out of the 2006 civic si in your car
Old Apr 5, 2006
tuner04civic's Avatar
spell check pwns you
k20a2 is in 05 and 06 type s. you can put a bunch of motors. k20z3(new si) k20a3(7thgen si) k24a1(crv) k24a2(tsx) etc etc
p.s. try searching this has been covered so many times
ibtl
Old Apr 5, 2006
misterpho7's Avatar
My bro has the 05` rsx-s and it has the K20Z1, I heard it has a Drive-by-wire throttle system and that would cost alot to put into a non drive by wire car.
Old Apr 5, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
u can basically put any k20 motor in there.. there is no way for them to know what year the car came out unless they tracked it... but even then they wont be as strict on it.. as long as its the same generation of cars... look at it this way...
what if you blew the d17 motor u have in your car right now and its an 05.. u go to the junkyard and find an 02 motor with only 2000miles on it to replace the motor... its the exact same motor but its older than the car you have...
will they give a sheit??.... no.. if you wanna be technical about it then yea ur not supposed to be putting older motors in your car thats lower than a 2005... but will they care.. in my honest opinion.. NO... the 2 motors are identical from the time the air enters to intake to it exits the exhaust its all the same...
you gotta remember that the only reason they say that is for emissions purpose... basically all 01-05 civics and newer to 02-05 rsx and anything newer all now use the same type of emissions control..
so as long as you stay within your generation then you will be fine
Last edited by xproductionz; Apr 5, 2006 at 10:49 PM. Reason: Automerged Doublepost
Old Apr 5, 2006
misterpho7's Avatar
Thanks man, thats what I wanted to hear. Just didn't want any problems with the law.
Old Apr 5, 2006
as much as what i said does make sense... you gotta think about it... even if you do the swap.. do they check to make sure your motor in your car is the oem motor...??? in the 3 different states i have lived in they have never once checked the motor... as long as you pass there emissions tests and what not then you will be in the clear
Old Apr 6, 2006
e04241's Avatar
e04241 is an unknown quantity at this point
just a question (im not from US)
so whenever you do swaps, you dont submit any papers to the DMV anymore?
Old Apr 6, 2006
anymore??? that states that i have lived in you never had to submit paperworks for a swap
Old Apr 6, 2006
HondaLuver's Avatar
Its a celebration bitches!
Cali does and i have done it already...
Old Apr 6, 2006
diskreet's Avatar
ibtl
dbagaus
SOHC D17Ax non-VTEC - VTEC Engine Swaps
70
Feb 22, 2023 04:26 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
codys civic
May 31, 2015 03:28 AM
ClutchMasterOG
May 31, 2015 03:25 AM
viper775
Dec 9, 2001 10:52 PM
