Gasoline
Old Mar 28, 2006
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
Gasoline
Well I let my my brother drive my car one day, he filled up the tank with 87 octane, now there is an engine light, can gas really set off the engine light?
Heres my setup
M24 BB turbo
Custom piping
RSX-S injectors
Greddy Emanage
STOCK EXHAUST <-----changing soon
STOCK SPARKPLUGS <--changing soon
I'm running rich at the moment I'm also getting tuned this weekend.
My car revs to about 4000rpms and then it boggs so its in safe mode. But off the line I guess it switches to an open loop and allows me to push the car.
Old Mar 28, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
All I know is that stock plugs are a big NO NO when your car is turboed. Hopefully your super rich and haven't detonated yet.
Old Mar 28, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Its either knocking like crazy hell because you don't have enough octane, or you're blowing the spark out.
Old Mar 28, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Add octane booster for now, otherwise you may blow head gasket at the very least.
Old Mar 28, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Change your spark plugs! go colder on um. gapped at abuot 32? thats what mine are but i dont have a d17 sooo best guess right now. Also add NOS octane booster perferable the black bottle. and dont go over 3000 but run that crap gass out and put 91 93 what ever yall have up there in it.. Or add about 2 gallons of 110 lol.
Old Mar 28, 2006
Well, I wouldnt think that stock plugd be a huge problem. Unless they are at the end of their life, they should be ok.
My OEM spark plugs were Denso IK20, exactly whats needed for street boost (as the forum says). And I also had stock exhaust with turbo, before I installed my 2.25" OBX..
I'd rather look into upgrading fuel octane now, rather then plugs and muffler.
He has CEL with limp mode activated. This might be caused by MAP sensor and not necessary by plugs or bad fuel.
BigE19 what are you using to cover the boost, Missing link or emanage voltage clamp?
Old Mar 28, 2006
Ps. go to an auto store and have them read your ODBII code
Old Mar 28, 2006
Good idea.
Old Mar 28, 2006
dezod's Avatar
7thgen Power Maker
Just add an octane booster. Probably dentonating like crazy
Old Mar 28, 2006
aznrocka's Avatar
aznrocka is an unknown quantity at this point
yes add octane booster and check your gas cap too...a loose gas cap does cause the engine light to come on but you def. need more octane than 87 for boost
Old Mar 28, 2006
BigE19's Avatar
emanage
02 sensor not present
Old Mar 28, 2006
Do you have connected emange MAP voltage clamp?
jttegx
Apr 11, 2005 12:05 PM
LubeControl.com
Mar 23, 2005 09:45 AM
LubeControl.com
Mar 18, 2005 09:53 PM
gearbox
Sep 8, 2004 08:57 PM
pnoyster2k1cvic
Feb 24, 2004 01:58 PM
