BoostED..... Boilermaker Style. (Edited 4/11/06 see page 4)
Old Mar 26, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Ladies and gentlemen, I'm exhausted. I drove over 900 miles to spend about 14 hours under the car this weekend, but... the turbo has landed.
First things first, I need to publicly thank Gerry (02FPcivic) who not only helped me put this together this weekend, but let me crash at his house. A truly nice guy and I don't think I can thank him enough for the help.
Lets get the party started... someone yank my crank
I'm not going to go big time into details here, a lot of this stuff is known, and I don't intend to make a DIY, but I've got some pointers. Enough of this stuff is pretty well known, and if you don't understand it, you need to learn it before trying crap like this. If you want my opinion, even if you buy a kit, this is NOT a driveway DIY project. You need someone who can TIG weld, and you probably also need some saws and other tools to do metal work with.
Sufficient to say, mine is custom, and there are no plans whatsoever of duplicating it.
This is the inside of the oil pan in case you've never seen it
This is the oil pan with a return bung welded in (this is the part where you need the TIG), don't bolt it in, the oil pan side isnt flat. Also 1 tube of Hondabond= 1 Oil pan Gasket
Good aim puts the hole above the sump baffle, between the bolt holes and between the support ribs. Take the pan off before you drill, and remove the baffle so you're sure to get all the drill shavings out.
We burned out the cheater pipe, so now its a true 2.25" DP. It was flanged, and so is the turbo DP.
I don't need no stinking charge pipes! Thats the top of the intercooler, into a 4 ply reinforced elbow, and into the engine. Piece o' cake.
Side note: the intercooler is a side mount, don't ask me about it, I'm pretty sure no one else wants to deal with what we had to do to make it work. Good thing is there's basically no charge pipe. We welded an elbow to the turbo compressor housing, it goes to an elbow which feeds the bottom side of the IC, I'll post a picture later.
Getting a little short on room by the time we got to the intake. It fits, but its all tight. I'll probably end up with a cylindrical filter rather than the conical one, and may end up making the lower radiator hose into a partial hard line.
Somehow it all fits....
The other side
And the crazy *** downpipe, it clears the AC, barely. its not done yet, it still needs to have the WG dumptube put in, and get welded together.
I'll post more later, the parts are all still in my trunk.
Its a GT28R, on a HKS manifold, yes we had to notch the core support, but everything else fits. I would think with a smaller compressor housing you wouldn't need to mess with the core support.
IT DOES RUN (See page 4)
Don't ask me how it feels, or anything of the sort. Its not installed. We test fit and mocked everything up, and if you haven't figured out by now based on what I said about the DP not being done, etc..... its not installed. I'll be at Summit Point next week, I didn't want to blow it up a week after installing it. Its going in April 9.
Old Mar 26, 2006
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
very very nice, but you're the best at everything you do to your car, and this is no different.....sleeper style!
Old Mar 26, 2006
EM2 Bluez's Avatar
EM2 Bluez is an unknown quantity at this point
One sick *** ride you got there bro.
Old Mar 26, 2006
tuner04civic's Avatar
spell check pwns you
wow, nice set up. good job. hope the rest goes smooth for u
Old Mar 26, 2006
icedcoco's Avatar
icedcoco is just really niceicedcoco is just really niceicedcoco is just really niceicedcoco is just really nice
another nice *** job, as always. im feening to see that whole job done and i gotta see that side mount intercooler in person....
Old Mar 26, 2006
Black03civic's Avatar
sweet cant wait to read your review of the product
Old Mar 26, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Should be pretty stealthy. We added a port to recirculate the bov to keep it quiet after those pics were taken. What a bastard it was to get it all in there. Everything seems great though, I can wait to see how it all works out.
Old Mar 26, 2006
wow amazing setup. glad you got it together.
Old Mar 26, 2006
SLO REX's Avatar
250+ awhp Stage 2
looks awesome.
Old Mar 26, 2006
tfnaaf's Avatar
BLDNPSI Mod
Looking GOOD!
Old Mar 26, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Talk about unique............
Will there be any loss in performance because of where the IC is?
More pics, I wanna see how it fits in there.
Old Mar 26, 2006
Jap-Euro Fusion
More than likely yes,but I have my reasons for putting it where it is. The minimized drop in pressure should help make up for the slightly higher intake temps. I've got some ducting tricks up my sleeve.
Old Mar 26, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
dyno asap! ;P
Old Mar 26, 2006
Al Gore FTW's Avatar
jdmtytedoridori
wow, awesome
Old Mar 26, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
nice. im gonna have to take a page out of your book, like i did with turboengnr.
Old Mar 26, 2006
ncirom2003's Avatar
thats freakin sick!, why is your pan aluminum? mine is steel and a larger baffle thats spot welded in not bolted.
Old Mar 26, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
very nice...you still plan on auto-xing it?
Old Mar 26, 2006
K20me's Avatar
Nice setup man!
Old Mar 26, 2006
tfnaaf's Avatar
BLDNPSI Mod
EX = Aluminum pan
Old Mar 27, 2006
turboengnr's Avatar
DONT PANIC
Looks sweet! I cant wait to see the results and hear how close it is to your expectations.
Old Mar 27, 2006
XxJDMCivicxX's Avatar
What he said! Also your helping me decide between the gt28rs and the gt30
Old Mar 27, 2006
Jap-Euro Fusion
well I don't think I'd be much help given that they're both T3 based and 28R is more T25 based.
Old Mar 27, 2006
TheSmuggler's Avatar
So hows it run?
Sorry Boil
Old Mar 27, 2006
HyaBoosta's Avatar
dam very innovative. I like to see people trying something unconventional. Good luck with the ducting work. this is very interesting.
Old Mar 27, 2006
Jap-Euro Fusion
More pictures.... here's the final intake arm, the big port is for the BOV recirc, the little one is a slashcut for crankcase ventilation.
This is the whole intercooler.... the top feeds the motor, the turbo feeds the
"sink drain" at the bottom.
The turbo has an elbow welded to the compressor, it couples directly to the intercooler inlet.
Old Mar 27, 2006
MajinB's Avatar
why such a small intercooler? how much boost do you plan on running?
Old Mar 27, 2006
Jap-Euro Fusion
Why do I need a big one?
7psi on a fairly small turbo doesn't need an enormous intercooler, this one should be more than enough to support 180 or so HP without issue. Why waste the pressure drop with a 28x6x3 core when I don't need to?
Old Mar 27, 2006
MajinB's Avatar
well i figured it would be a small boost setting. just wondering. i understand, if there is no need, don't do it.
Old Mar 27, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
the way you have it positioned, if you ever go to the track, just pull off your headlight...
the smic should get sufficient flow there, might want to route some kind of plastic stuff for a "ram air" type thing...but itll be fine
Old Mar 27, 2006
Jap-Euro Fusion
I'm gonna cut out a lot of plastic from the lower grill where the foglight should go, then trim some metal out from behind it, and put a big NACA duct in there. The intercooler is actually below the headlight, I don't know if pulling it would help a lot, but it would surely put some ram air into the turbo.
Another duct from under the car in the splash guard (part of which is going bye bye) and I'm considering pulling out the radiator overflow and replacing it with a smaller catch tank... which would free up a huge opening through the lower radiator mouth. Its in a pretty good spot for airflow with a couple minor modifications.
