dry nos
Old Mar 20, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
dry nos
whats the problem with dry kits? what is the big taboo about them?
if you wanted to run a turbo with a nitrous setup does it have to be a wet kit? im talkin like 30-50 shot only. thats all.
Old Mar 20, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
let me be real with you. I put a 50 shot of zex dry nos in my integra gsr. the car had about 80,000 miles on it. it tore out the clutch in 1 day and the head gasket in three. dry nos will lean out your car to an extreme and imo is a stupid thing to use when you can buy the wet kit which will give you more power safer becouse of the simple fact that it adds fuel.
Old Mar 20, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
You can run a dry shot if you have an excellent ECU setup (AEM EMS) and fuel setup along with your turbo that can add as much fuel as you need. You see, the main issue is you have all this extra air going into your engine, now where are you going to get fuel???
Old Mar 20, 2006
MajinB's Avatar
well why do they have the dry system anyway? if its so dangerous what is the point.
Old Mar 20, 2006
ramcosca's Avatar
Words on a User Title
People like danger. That's why there's skydiving or cliffhanging.
Or ricing out cars. I mean, what can be more dangerous than putting a huge bodykit, chrome wheels and a huge wing on your car? That car's gonna be fast, for real!
Old Mar 20, 2006
scansel912's Avatar
It can be easier to add fuel to other vehicles, but in our case, its very difficult.
Old Mar 20, 2006
MajinB's Avatar
ok, so is it the bottle thats different or what? i need help here. can you convert a dry kit to wet? help?
Old Mar 20, 2006
Slow Gold's Avatar
yes most dry nitrous setups can be modified to wet. here a little fyi on nitrous. the only thing that makes nitrous wet is when fuel is mixed with nitrous gas. meaning both kits use the same nitrous gas only the wet kit is spliced into the fuel line then a nitrous and fuel line meet then when you hit the button they mix and boom dry nitrous becomes wet. there is no liquid nitrous. any other q's?
Old Mar 20, 2006
MajinB's Avatar
yea if i get a dry, and run like a 30 shot. but never actually spray, just for show, will it really matter? like i would spray once to see if i hooked it up right lol. thats about it. i plan to mount the bottle in the trunk
Old Mar 21, 2006
Slow Poke's Avatar
Slow Poke is an unknown quantity at this point
even if its for show i would do a wet set up just cuz its better and safer if u ever do want to spray.. Makeing a dry kit to wet is ez u just got the fogger and the tee to tap in the fuel line and thats about it..
Ps.. I lots 2 motors to spraying its the devil
Old Mar 21, 2006
R1Style's Avatar
If you're gonna setup a kit for show then just buy a bottle, mount it in the trunk and call it a day.
In all honesty, I wouldn't run a 30shot with dry nitrous on my car... it's not worth the risk.
All that money for a kit and install only to not use it is a waste. Get a wet kit, install it and not only can you show it but now you can use it.
Old Mar 21, 2006
MajinB's Avatar
ill just get a wet kit then
Old Mar 22, 2006
turboengnr's Avatar
DONT PANIC
a complete dry system comes with a fuel pressure regulator. When you press the button for the nitrous, the fuel pressure regulator closes off your return line. This adds more fuel, but it is not a metered amount. It just dumps more fuel through the injectors.
A dry system will not work on a stock 7thgen civic because they do not have a return line. The pressure regulator goes on the return line.
Now if you were to convert to a return system, then yea, you can run a dry setup. But otherwise, you will kill your motor.
jtcavey
Sep 30, 2015 02:18 PM
General DIY
Sep 25, 2015 08:02 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
martinsmartin
Aug 15, 2015 07:34 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
