cant go beyond 4k
Old Mar 15, 2006
jacky599r's Avatar
jacky599r is an unknown quantity at this point
cant go beyond 4k
well. boosted. got a new apexi BOV and it was great. however, i dont seem to be able to pull over 4k rpm. its like i will have a violent jerk when i reach the 4000 rpm rev and i dont dare to cross the line. what could go wrong? heard something abt the fuel lines or rails needs upgrading. true? anybody?
p.s: boosters, have you guys done any return fuel system? change fuel rails? whats the fuel system that you guys are running?
Old Mar 15, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Car is in safe mode........
CEL???
Old Mar 15, 2006
mxcivic's Avatar
mxcivic is an unknown quantity at this point
i used to have the same problem, and it was the fuel, what fuel upgrade r u using ? btw i have a brand new return fuel system .....
Old Mar 15, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
CEL???
I'm thinking about the same thing.
Unless you run insane boost, you dont need to upgrade fuel lines or fuel pump.
Old Mar 15, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
map sensor might be seeing boost. . .
Old Mar 15, 2006
TheSmuggler's Avatar
Probably need a missing link or voltage clamp from the emanage
Old Mar 15, 2006
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
i'm willing to bet money on the spark plugs or wires.
Old Mar 15, 2006
SleakCivic02's Avatar
SleakCivic02 should not be trustedSleakCivic02 should not be trusted
i am betting its the fuel, he doesnt have enough fuel, its running in safe mode, or its creating its own rev limit, or it feels like it, the whole car starts bouncing. sometimes you get backfire??? more fuel then, rsx injectors and emanage, or apexi s-afc
Old Mar 16, 2006
turboengnr's Avatar
DONT PANIC
either you dont have a good fuel system (or horribly tuned), or your MAP sensor is seeing boost.
Old Mar 16, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
^agreed
Old Mar 16, 2006
mxcivic's Avatar
samea here and i have a brand new SLP return fuel kit and rsx injectors sitting y mu closet
Old Mar 16, 2006
jacky599r's Avatar
not enough fuel? at idling its damn rich. black smoke and soot. and i can say its untuned for now. just running rich to play safe
so i need a return fuel system eh? im just running on management that does only fueling. no ignition no nothing.im gonna hook up emanage with injector,ignition and boost. its gonna help? just to ask does the y8 mani support returnless fuel system? im gonna bolt it on.
o yeah. ive got a cel. and when i recycled my bat..the cel went off. but it came back on afterwards while travelling on highway. ive not cat. so i cant tell...
desperate.
Old Mar 16, 2006
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
how much will it cost to tune? where can quality tuning be done?
Old Mar 16, 2006
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
desperate.
where'd you find this turbo kit? by the side of the highway?
Old Mar 16, 2006
jknudsen's Avatar
MAVS FAN 4EVER
jknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the rough
This goes to show how investing some money on the front end of the project WILL cost less in the long run. I personally would never boost my car without doing some serious thought first, and then adding the necessary modifications to go with it. So many people are like, oh yeah i'll turbo it, and forget that they need upgraded fuel systems, engine management, tuning....to do it right it costs money, but to me having a car with a blown up engine and having to flintstone around town costs more...thats my .02...not to down you dude, but if you fail to plan, then you plan to fail....
Old Mar 16, 2006
HyaBoosta's Avatar
yeah def. gonna need engine management! im sure your spraying way too much fuel,prob stock plugs,stock gap? map seeing boost. got alot work to do. park it till then.Return fuel system is not a must. it's great if your going for big numbers but the car will run fine up to 12psi on the returnless. oh and get that cel scanned, resetting it won;t fix anything.
Old Mar 16, 2006
at least he is boosted, and not stock..
Old Mar 16, 2006
C2i0v0i1C's Avatar
SuperMODrizd
a wire or plug problem? the car wouldnt start or would just run like ****.
Fuel? likely
MAP sensor? most likely
Old Mar 16, 2006
What turbo kit are you running?
As someone said before look into MAP sensor issues.
I've had same thing, cant rev past 4k rpm and CEL. I upgrated to "Missing Link" and not it runs smooth as stock.
Old Mar 16, 2006
Alex1's Avatar
I bet it's fuel too, the same thing happened to me when I accidentally installed the SF fuel system backwards lol.
Old Mar 16, 2006
this is what i did to make it go away, make sure you are using premium gas, 91 oct. or higher, if engine light on, clear it, unplug ur map sensor, drive it , let it idle for 40sec and plug the map sensor in. i did that and its good but not the best, still waiting fuel upgrade.... hope that helps.
Old Mar 17, 2006
turboengnr's Avatar
DONT PANIC
Here is my fuel system...
I planned this very in-depthly. I conversed with some of the best tuners in california to come up with a method of controlling these, and how to get the most power and the best drivability.
I have been designing this turbo kit for over a year now. I did not plan on it taking this long. But it took 9 months to get my custom parts (pistons, rod bearings). But it was a good thing. Even though i know what i am doing, i did even more research. I talked with TONS of people, exchanged insane amounts of info and ideas with eachother. And now i think i have one of the best designed fuel systems possible. The only thing i think i could do to improve upon it is add an AEM instead of an emanage. And i will do just that when i get a bit more money. I would wait, but i have obligations to get the car running by April 8th. I have to race at IDRC nationals.
Old Mar 17, 2006
Looking very good!
Old Mar 17, 2006
jacky599r's Avatar
mayday mayday. ok. ive got myself a boost sensor. tuning on tues an post the results again. ok.this is gonna be damn long and hope you guys understan what im talking abt... probs again.
Basically, ive got myself a y8 mani matched with a b18 LS tb. i just wanna swap it in but it i heard a mechanic telling me the tps for the b18 is in opposite sense;alot of things to do and i need to refab a IAC in order to get it work with the d17. any1 can guide me? im skeptical with the mech i consulted.
IF i just swap the mani in... with our stock tb. whats there to be done to the tps,map sensor, bla bla. or is it a just bolt and drive kinda thing? any1 can share? the tb for y8 is the same as the b18?
lastly, those boosting and running on the y8.. what kinda injectors are you guys running? the mech said i need to change my injectors as they dont fit into the y8... damn stupid.
Old Mar 19, 2006
jacky599r's Avatar
ok.got myself an emanage. boost sensor and harness. ready. anything to note for the tuning session?
Old Mar 20, 2006
turboengnr's Avatar
DONT PANIC
make sure somebody well experienced with the software tunes the car.
Keep the a/f ratios around 11.2-11.7 while in boost, and keep the timing slightly retarded.
If you go too overboard on pulling the timing, you will lose a lot of power. If you dont pull enough, it wont be reliable for daily use and wouldnt allow for any inconsistencies in the quality of fuel you use.
Old Mar 20, 2006
jacky599r's Avatar
ok. well. this sucks.
got my stuffs all wired up. got onto the dyno. damn. my boost wouldnt hold. keep surging up to 1.4 bar. something wrong there. and boost comes in real slow...its internally wasgated. so what now?
then. i got him to do a rough tune. and hey. my car stalls when im driving with a/c on and it happends quite often on the highway. idle is abit jumpy and when im accelerating slowly. the car jerks... something like tapping the accel on and off kinda feel. this sucks. end of day paid and job not done. really lost man.
Old Mar 20, 2006
turboengnr's Avatar
DONT PANIC
what are you using to control the boost?
1.4 bar of boost is about 19 psi. Entirely too much for your motor.
Did you happen to get a dyno graph you can post up for me? How about an air/fuel graph? If you can post those for me, i can probably help you out a bunch.
Old Mar 20, 2006
C2i0v0i1C's Avatar
SuperMODrizd
19psi, christ. be careful
Old Mar 21, 2006
jacky599r's Avatar
ok. update. gee.when i start my car theres some white smoke trails. but hey after some driving. its no longer there. it doesnt blow when i step the throttle as well. just during start. and the car still stalls occassionally when i wanna shift from a higher gear down. any1?
ok. updates again. im using a mitsubishi GSR 4G93T engine turbo and injectors from galant VR4. anymore help?
