cant go beyond 4k
Old Mar 21, 2006
  #31
mocivic314's Avatar
mocivic314 is an unknown quantity at this point
standing ovation
Old Mar 22, 2006
  #32
jacky599r's Avatar
jacky599r is an unknown quantity at this point
bump...
need to know. if i have a greddy e manage boost sensor. do i still need the missing link? engine basically surges below 3krpm throughout the gears. and still stalls when im trying to shift from 5TH GEAR AND DOWN. damn. really need help
Old Mar 22, 2006
  #33
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I can help on the stalling issue, I had it as well.
Mine was happenning, when I was off throttle and when RPMs slow down to idle, engine stalled...
I may be wrong, but I've figured out as TB butterfly closses too fast and engine doesnt get enough air to burn, so it stalls...I've adjusted idle screw, so butterfly stays a bit open when throttle 100% off. Now engine has enough air to burn, so I've never had this issue again...
If follow what I said, then you'll see you idle a higher, may be at 900 rpms, but then stock ecu will put it towards 700 zone after few miles...
If you use emanafe MAP sensor clamp, no missing link needed. You either use one or another, but work well.
When I've not had emange clamp or missing link (I used something else that did not work), my car whould alway throw CEL and wouldnt revv past 4000...I'm was than certain it was MAP problem. Then Dezod sent me missing link and it made wonders. Trust me, it was day-night difference. You cant belive how happy I was when I learned that this was finaly over. Car felt just fabulous.
Old Mar 22, 2006
  #34
jacky599r's Avatar
ha. by MAP sensor clamp. i would presume its the boost sensor?still CELs. still jerks. haven got to try the butterfly plate thingy.
Old Apr 6, 2006
  #35
collinshill26's Avatar
collinshill26 is an unknown quantity at this point
which is better missing link or emanage pressure sensor?or r both work about the same?
Old Apr 6, 2006
  #36
both ok.
Old Apr 7, 2006
  #37
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
where can i get a missing link?? what the best price for it??
i found one on ebay for $50 not sure if its good for it
Old Apr 7, 2006
  #38
contact Dezod. He sold me one.
Old Apr 8, 2006
  #39
BoostedVik's Avatar
thanks. i did check out dezod.com
they are charging 57 + 12(shipping) = 69
ebay 55 + 6(shipping) = 61
savings of 8 dollars...its the same product
i made my mind up thanks guys and 1.7l acura el
Old Apr 8, 2006
  #40
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
but what's 8 bucks when you get such good customer service??? he's been really helpful to me and i haven't even bought anything yet...
Old Apr 8, 2006
  #41
BoostedVik's Avatar
right. thanks
Old Apr 23, 2006
  #42
04_CIVIC_HFP's Avatar
04_CIVIC_HFP is an unknown quantity at this point
so do you guys think it is the missing link? Because im currently having the same problems.
Old Apr 23, 2006
  #43
MAP sensor probably is the issue.
I recomend missing link (ML) over emange clamp, just becuase with missing link there is noting to adjust and connect. Also install looks cleaner under the hood.
Contact dezod, so he could send you ML.
Old Apr 24, 2006
  #44
Yes I just bought the missing link on sunday and ill tell you guys if that is the problem when I get it on.
Old Apr 24, 2006
  #45
BoostedVik's Avatar
cool, tell us how it goes!
