Crower Turbo Cam Dyno | Enjoy and see the power!
Old Mar 6, 2006
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Talking Crower Turbo Cam Dyno | Enjoy and see the power!
Mods with Before and After:
Before
Sf Turbo Kit
Greddy Emanage tuned by Apex Motorsports
Greddy E-01 Boost Controller,
Aem pulleys,
ACT Street lite Flywheel,
Exedy Organic clutch,
Poly Motor Mounts,
Bored out throttle body,
Kms Intake Manifold,
Rsx Injectors
After
Sf Turbo Kit A
em Ems 30-1030 tuned by Apex Motorsports,
Turbo xs Manual Boost controller,
Aem pulleys,
Poly Motor Mounts,
Crower Stage 2 Turbo Cam,
Crower Valves,
Crower Retainer Kit,
Crower Valvesprings, A
rp Headstuds,
Swapped Ex ported and polished (plus some other little work) head done by Exospeed on Lx block,
Kms Block Guard,
Aem 5-bolt cam gear,
Srt-4 524cc Injectors
Results:
Old Mar 6, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
nice ... how much boost before and after?
Old Mar 6, 2006
eye_see_you's Avatar
let the devil out
thats a nice jump there
Old Mar 6, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
how much psi?
Old Mar 6, 2006
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
Srt-4 injectors? Didnt know those would even fit our cars.
55whp/ 42wtq gain due to the engine build...thats pretty sweet (If im reading that right)
Old Mar 6, 2006
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Was the psi the same before and after.
Old Mar 6, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Also, food for thought, those are dynojet numbers. Take it to a Dynomite dyno. You will get "real numbers" hehe. My car will make 20 whp more on a dynojet.
Old Mar 6, 2006
truehonda's Avatar
Dynojet is a good standard to go by. Mustang Dyno's usually read a bit higher I believe... I may be wrong
Old Mar 6, 2006
02fpcivic's Avatar
I gotta find the link, you'll **** when you see the fudge factor that dynojet uses in there software programming. They openly admitted in an interview that they did that because they dont want their customers to get lower numbers. Dynomite are among the most accurate chassis dynos. The most common is the Dynojet, I do agree. However, it is a correct statement to say that Dynomite Land and Sea dynos are more accurate. Mustang dynos are even worse.
Old Mar 6, 2006
02fpcivic's Avatar
either way, if thats a pound for pound dyno, thats a big *** jump and a thumbs up is well earned.
Old Mar 6, 2006
dezod's Avatar
7thgen Power Maker
We used a DynoMite when tuning our Scion tC kit.
The mustang dynos typically read the most lowest, and DynoJet falls in the middle between DynoPak (reading the highest).
I did notice 1 BIG variable here Eddie, in the 1st session an E-manage was used and then the AEM standalone was used on the 2nd round. Much of those gains can be gotten from the AEM's vast tuning ability alone. I am sure the cam with tuning is good for 15whp alone.......
Old Mar 6, 2006
truehonda's Avatar
Absolutley, our customer was not able to single out the tests from the Cam, but as you can see, the posted numbers on the cam were in fact true 15-20whp is possible if not more.
Old Mar 6, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Hey at least you posted numbers. Repped
Old Mar 6, 2006
mrDFWmechanic's Avatar
not bad at all, finally someone posted some dyno numbers
Old Mar 6, 2006
02fpcivic's Avatar
Hell I got 202 and 181 on the Dynomite dyno with 5.5 psi at the manifold, crower custom grind and the aem. The cam and engine management are well worth the money.
Old Mar 6, 2006
Michalo187's Avatar
Abortion Survivor
Both times was 10 psi and I used the same dyno.
Old Mar 6, 2006
02fpcivic's Avatar
yeah pound for pound thats a big increase. pretty sweet.
Old Mar 6, 2006
Michalo187's Avatar
Abortion Survivor
Yeah to tell you the truth i was pretty surprised. It pulls a lot harder. I could instantly tell the difference with the cam and then with the ems it was like heaven
Old Mar 6, 2006
drunkenmagnum's Avatar
ha! im glad you posted this, im getting my cam installed tomorrow. i hope to get it dynoed again real soon. i will be running 6psi until my boost controlloer gets here later this week.
Old Mar 6, 2006
Michalo187's Avatar
Abortion Survivor
dude seriously your gonna be happy with how it pulls. Post again how it feels after you floor it.
Old Mar 6, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
.....damn...i want one!!!
Old Mar 6, 2006
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Nice torque. I would question the tuner though if you only got 159 whp out of 10 psi with the emanage and RSX injectors. You should be able to squeeze more out of your new setup as well, especially with the AEM EMS.
Overall you put together one nice setup, congrats!
Old Mar 6, 2006
tripledoublegs's Avatar
Euro-Spec
That was Michalo187
I don't think TrueHonda dynoed at 10 psi. More like 7 or so.
Old Mar 6, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Good #'s!
Honestly, I dont like the power curve. Max HP's in the area of 5500rpms.
Looks like full boost comes at about 4000 prms and power fall off. I'm not sure what turbo Mike is running, but power should'va continue to climb.
Especialy with ported head and hot cam.
Old Mar 6, 2006
Michalo187's Avatar
Abortion Survivor
I dynoed for truehonda. Yeah i should squeeze more but its hard with the emanage and this last time as you can tell in the dyno we believe my clutch begin to slip so i should have more. Its a t3 super 60
Old Mar 6, 2006
ncirom2003's Avatar
nice!
i so cant wait, ive had my turbo kit for almost 6 months sitting waiting while i pile up parts, now my last part came in (stage 2 turbo cam and springs) and this week im installing hopefully.
might not get a before and after dyno but ill try for eveyrone.
again, good job michalo
Old Mar 6, 2006
Michalo187's Avatar
Abortion Survivor
Thanks! The cam is the best thing after you get your turbo, seriously guys come back and post your feedback of the cam when you guys install them so people can actually know from more then one person how it pulls
Old Mar 6, 2006
ncirom2003's Avatar
yea i definately will (although i wont know the difference of just the cam as opposed to my whole setup), i just wish i had the ems so i could get the extra 500 rpms out of the cam, and not be limited at 115 on the highway.
Old Mar 7, 2006
dezod's Avatar
7thgen Power Maker
Where was this tuned?
Old Mar 7, 2006
Michalo187's Avatar
Abortion Survivor
1st post says Apex Motorsports its a shop in Tucson, Arizona. They are aem certified and you can check online at the Aem website
