A3 Engine Mount Questions
Old Feb 28, 2006
02ciVike's Avatar
02ciVike is an unknown quantity at this point
I have searched the k20 FAQ thread and have not found a definite answer for this.
I am considering doing an k20a3 swap into my EM2 coupe.
I have heard the engine bay dimensions are similar between the Si and EM2. I would like to know that if I use the the subframe from the Si will the OEM Si engine mounts work without modification?
Also will the Si axels be the best fit in this situation?
Old Feb 28, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
i think you will still need aftermarket motor mounts.
Old Mar 1, 2006
02ciVike's Avatar
Can anyone confirm this?
Old Mar 1, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Yeah you do need custom mounts..
Looky here...
Old Mar 1, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Yes you do need the mounts cause the k-seires engine sits on the oppisit side of car, and yes the si halfshafts will work just fine.
Old Mar 1, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
you can use the si front and rear mounts.... but why do that when the hasport already comes with the rear ones anyways... you can put the oem front from the si if you want to
mikemc422
Aug 9, 2018 05:41 PM
zack22490
Apr 29, 2015 03:17 PM
bsmiley
Apr 27, 2015 01:27 PM
streetglower123
Apr 12, 2015 10:56 AM
WhosYoDadday85
Nov 13, 2001 09:38 PM
