better fuel manag. for my tsi kit soon to come :)
Old Feb 21, 2006
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
soo I decided to ditch the extra 2 injectors on the throttle body ...
So I should be running the emanage with rsx injectors pretty soon since they seem to be pretty much a bolt on with longer bolts ("30mm, M6x10, and 2 washers")
I bought a brand new emanage from a guy on clubrsx (emanage's are universal correct?)
and dezods PnP (plug and play) harness.
now all I should be needing is to buy the injectors intall it and tune tehhh car :-p.
Hopefully this upgrade pays off
Ill keep you guys updated
Old Feb 21, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
you should get the support tool and pressure sensor too.
Old Feb 21, 2006
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
Hey. I have the same kit and the RSX-s injectors aswell. Please let me know what you used to space out the injectors, because the RSX seat alot lower in the fuel rail then the stock injectors.
Old Feb 21, 2006
eye_see_you's Avatar
let the devil out
andyman is running the same injectors I believe
try this
http://www.7thgencivic.com/forums/sh...d.php?t=217534
Old Feb 21, 2006
yes support tool is something i will be getting also
I have heard that you can do just find without the pressure sensor... but it just makes tuning easier?
whats the pressure sensor exactly for?
Old Feb 21, 2006
quoted from another member who used rsx injectors on stock fuel rail "30mm, M6x10, and 2 washers"
Green02civic
Jul 27, 2015 10:48 PM
Ariah J. Davis
Jul 20, 2015 07:15 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
chrisjackson321
Jul 12, 2015 03:00 PM
