intake manifold?
Old Feb 12, 2006
jacky599r's Avatar
jacky599r is an unknown quantity at this point
intake manifold?
well.im boosted and looking for an intakemanito replace the plastic crap that im currently running. would like to use the y8's IM. any1 running them? and what other throttle bodies can i look into? cheers...
p.s:anyone has either a y8 IM,TB OR a 7th gen tb to let go?
Old Feb 12, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I might be selling a y8 manifold conversion soon. It works pretty good but Im on to bigger and better things.
Old Feb 12, 2006
eye_see_you's Avatar
let the devil out
andyman is running one
Old Feb 12, 2006
turboengnr's Avatar
DONT PANIC
im running a GSR manifold. Soon to be yet-another "cant be done" manifold as soon as i swap in my build D17
Old Feb 13, 2006
jacky599r's Avatar
ooo. ok. ive just gotten myself a y8 mani and going for a 94+ b seires throttle body to be port matched and bored to 64mm by maxbore.com. what you guys think? anyway. im using a different fuel rail and injectors. will it be affecting me when i try to install the intake mani?
Old Feb 13, 2006
jacky599r's Avatar
btw. whats with the tps sensors, and all sorts of valve? damn confused and i need a solution quick. can i just get a throttle body from a B and bolt it to the y8 and run off my 7th gen????? desperate!
Old Feb 13, 2006
jacky599r's Avatar
bump for help?!
can i just use back the sensors that the 7th gen has on a y8? fuel rail as well?
Old Feb 13, 2006
02fpcivic's Avatar
nah they need to be changed. I made a flange to convert to a D17 tb, includes idle control and tps as well. All youd hafta do is either rewire the map sensor or maybe you could stretch a 3/8 vaccuum hose over it and clamp it. I have the aem 3.5 bar map tapped into the plenum.
Old Feb 13, 2006
02fpcivic's Avatar
use the d16 injectors, and rail. you will need to adapt the fuel feed line and if you are staying returnless, block off the fpr port.
Old Feb 15, 2006
jacky599r's Avatar
hmmm. ok, my stokc fuel rail is out. so im going to run the y8 with a 94 civic b series tb. anyone has dealt with his before? or should i just stick with the y8 and get it bored to 60mm. im on the greddy side. hoping to get 64mm with the b series tb with a port matced y8. and you have a pic on how to get the y8 in with the flange and the tb? i appreciate your help alot. cheers.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
