how to wire in a reverse gear lockout??
Old Feb 10, 2006
vietrice507's Avatar
vietrice507 is an unknown quantity at this point
hi all, im doing a K frank swap into my 2001 civic coupe, i hav a couple questions if anyone know how or know where to get the answer let me know i appreciate that.
I hav a base RSX engine harness but im using type s 6 speed trann so i need to wired a reverse gear lock out, how do i do this??
Old Feb 11, 2006
turboengnr's Avatar
DONT PANIC
i thought they were built into the transmission? Doesnt it have a block in the shift gates that engages while moving forward to keep you from going into reverse?
Thats how my corvette is anyway
Old Feb 11, 2006
no, i know ther is a wire we have to connect to make make the reverse gear lock out, but i dont know which one and where to connect.
Old Feb 11, 2006
kornsined's Avatar
yeah i heard something about this too. i may have the same problem. kinda worries me.
Old Feb 11, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
its one wire that goes from the ecu straight into the tranny... if you have a 6speed tranny look on top where the cables go and you will see something that looks like a vtec solenoid...
Old Feb 11, 2006
R1Style's Avatar
weird I thought these were mechanical... learn something new everyday.
Old Feb 11, 2006
could you plz give me more detail about this. and yes i saw the thing looks like vtec solenoid. where and how to connect it to the ECU but i have kpro dose it make a different???
Old Feb 12, 2006
the only time you really need to worry about not having a reverse lockout is when you go from 5th to 6th gear... but let me look for some stuff and i will let you know unless someone chimes in before i do
Old Feb 13, 2006
bump for the nite.
Old Feb 13, 2006
okay.. on connector B (24pin) clip
look for pin number 7 on the clip..
it should be a green/white wire
it puts out a + charge... that goes to the vtec solenoid looking thing on the tranny
if you look at the the clip on the tranny it has 2 holes.... if you look at the clip with the tab part of the clip on top then pin1 is on the left and pin2 is on the right..
pin1 - gound
pin2 - postive (to ecu)
Old Feb 13, 2006
turboengnr's Avatar
DONT PANIC
try following that diagram to wire it up.
Name:	wiring diagram.JPG
Old Feb 14, 2006
isnt that the same thing i said.... but you gotta ground pin1 cause i tried it on my tranny just now and if pin1 isnt grounded it wont engage
also when the car is below 9.4mph the voltage coming out of pin7 is 12v...
with a vehicle speed above 12.5mph voltage will be 0v...
i have the service manual so i can basically lookup almost anything
Old Feb 14, 2006
turboengnr's Avatar
DONT PANIC
it is the same as what you said. I just drew out a diagram to help.
Whenever i do electrical, i always draw myself diagrams. I was just trying to help visualize what he said.
Old Feb 14, 2006
thankew very much guys i will try to wire it up this weekend
Old Feb 14, 2006
again thaks alot guys very helpful infor.
CarStuff
Dec 6, 2020 12:52 PM
EdtheChipmunk
Jun 19, 2015 10:37 AM
Blazz
Jun 4, 2015 01:04 AM
cruisers10
May 12, 2015 10:46 PM
Russps
Nov 8, 2001 02:00 AM
