ecu problem
Old Feb 10, 2006
fi dx's Avatar
fi dx is an unknown quantity at this point
ecu problem
okay...i'm in the middle of swapping a k20 and i have everything hooked up and ready to fire up the car....all harnesses are plugged in and i have fuel and spark....the car will crank...but will not start
so then i try using the ecu from my single cam d motor....it starts up right away....so i try to use the ecu i was given for the swap and it still won't start..
is this a fried ecu...or something else
do i need to get my key matched to the ecu at a honda dealership?
Old Feb 10, 2006
yes the last one. ecu doesn't recognize the key code.
Old Feb 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
which k20 motor and ecu do u have?
if you have the type r ecu, there is a fix u can do temporarily to start it without reflashing the key.
don't run the itr ecu with a k20a3 or a2 though.
Old Feb 10, 2006
fi dx's Avatar
not a type r ecu...
i figured it was probably the key not being recognized...but it cranked so that threw me off a little bit
Old Feb 10, 2006
turboengnr's Avatar
DONT PANIC
if you have both spark and fuel in the cylinder, it will fire.
fuel + air + spark = boom
if its not starting, you are missing one of the above. (unless the cams are installed incorrectly)
Old Feb 11, 2006
iamboo's Avatar
Retired - SoCal FI Mod
you need to reflash the key to work with your ecu. the immobilizer is kicking in and not allowing you to start the car.
Old Feb 11, 2006
turboengnr's Avatar
DONT PANIC
the immobilizer eliminates the spark, right? Or does it eliminate the fuel? I know it cuts one of them.
Old Feb 11, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
it elminates both... there is a way to get around the fuel pump on the US ecu but not the spark.. thats built into the ecu.. why do you think everyones using kpro... if not then you need to get the ecu reflashed
Old Feb 11, 2006
fi dx's Avatar
fuel pump definitely primes...i'm not sure about spark...
if i was to get my ecu reflashed by hondata would that eliminate the immobilizer...i know that you have to send them your key, ecu and immobilizer..would that work?
Old Feb 11, 2006
it is supposed to cut fuel and ignition
Old Feb 12, 2006
if you fix the immobolizer by getting your key reflashed then yes it will work
Old Jul 5, 2006
mclean987's Avatar
mclean987 is an unknown quantity at this point
help anyone know where i can get ex ecu 5 speed and key ??
Old Jul 5, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Look into "For Sale" forum or ebay
Old Jul 5, 2006
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
if you don't have k-pro and you don't have a typ-r computer you will need to program the key witch will have to be done by the honda dealer, i mod cars and know what needs to be done plus i work for a dealer do check your pm and i will get it done for you
juror
Jun 9, 2015 02:15 PM
01civyv3
Jun 2, 2015 05:21 AM
beveragemp
May 25, 2015 07:11 PM
McD
Apr 22, 2015 05:28 PM
dooner24
Apr 14, 2015 07:51 PM
