t28 BB
Old Feb 8, 2006
dipset7's Avatar
dipset7 is an unknown quantity at this point
t28 BB
I searched but really did'nt get the info i needed,about the t28bb it was said that with this turbo from the TSI kit upgrade you cannot run a/c is this true? Any members find a way around the problem was it the downpipe hit the a/c lines or is it that the ic pipes have to be customized somewhat from the kit. Any feedback would be appreciated!!! Holla ------
Also whadup ANDYMAN did you get my message hit me up i might need your help soon!! ----PEACE
Old Feb 8, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Nothing needs to be modified or removed with TSI kit.
abs, a/c, p/s, washed bottle - all stays.
t28 is not much different from t25
They both have same exhaust housing, but t28 has bigger intake housing, I think it t3 intake.
Thats about it.
Old Feb 8, 2006
dipset7's Avatar
Thanks alot really appreciate it!! Do you have a guess-tamation on how much of a number difference is from a t25vst28bb?
Old Feb 8, 2006
tuner04civic's Avatar
spell check pwns you
well i know that the t28bb you may modify a few parts in engine to properly fit. i know exturbo06 had to from what i remember.
Old Feb 8, 2006
andyman97's Avatar
Turbo Guru
Thats about it.
What's an intake housing? The turbo that comes with the TSI kit is a measley t25. You'll be very limited as far as power output, depending on your goals. I always recommend a good t3/t4 over most others for a smaller engine. Super quick spoolup and depending on the trim, extremely good top end and they flow great.
There is no T28 ball bearing turbo. Garrett makes a t28 turbo but it isn't ball bearing. The ball bearing turbo Garrett does make is a GT28 r or rs. These are decent turbos but pretty pricy, imo.
As far as the specs on the t28, it's a good sized turbo but due to the large size of the turbine housing, not to mention the trim of the turbine and compressor wheels, it won't spool up very quickly, it's a little out of the efficiency range for a 1.7.
Old Feb 8, 2006
tfnaaf's Avatar
BLDNPSI Mod
i beg to differ on the spool up time of a GT28R if thats what your refering to. Im in boost at as low as 2100rpm, and 7psi at as low as 2500rpm. I sometimes wish it was a larger turbo so i wasnt in boost as much
Old Feb 9, 2006
civicskater's Avatar
Chicks dig my scent
my t28 is fully spooled by 3600rpm. Sometimes I wish it had a little more pull on top but the torque (before 5200rpm) is fantastic.
Old Feb 9, 2006
dipset7's Avatar
Andy i where did you hear that they don't make a T28bb because they're all over ebay.
Old Feb 9, 2006
andyman97's Avatar
Turbo Guru
Nah, I was referring to the t28. The ones I've seen advertised run a .86 ar turbine housing. They flow alot of air but a turbine housing that big affects spool, which is why for most sohcs, street made power is typically done with a .48 ar.
Old Feb 9, 2006
andyman97's Avatar
Turbo Guru
What you're probably seeing is a gt28 which is ball bearing. You can have a t28 made into ball bearing by having it rebuilt with a ball bearing center cartridge. Most turbo dealers that I know get pretty much every turbo garrett makes off the shelf and any t28 that would go out as a bb would have to be done in house as a custom job.
Now, the sylvias use a t28 bb, but I don't believe its found anywhere else and I'm not sure of the specs on that turbo, either. There are limitless combos you can find with turbos but ebay isn't the place I'd look for one.
Old Feb 9, 2006
dipset7's Avatar
I see what you are saying. If you get a chance check out ebay motors and type in D17 TURBO and tell me what you think about that TSI kit for sale does it look complete. I don't wanna reach really high numbers just get resonable amount of power out of my car. I also wanna keep it a daily driver of course with that turbo you think it will be okay for traffic in Killeen? I got your # man my wife took my phone by accident so i'll have to call you when she comes back from San Antonio. ----Peace
Old Feb 9, 2006
ncirom2003's Avatar
hmm learning alot about the t28 here. doesnt garrett make the t25 bb, or would that be a in-house job like you were saying, rebuilding it. because ive got the tsi kit and id like to upgrade just a little to a bb turbo....im pretty sure it has the bottom of the line choice for turbos for this kit.
sorry to jack the thread, just hoping this will bring outmore info on the t28's and t25's
Old Feb 9, 2006
Just to add few things...
Both t25 and t28 are good turbos for a basic street kit.
If t3/4 is quick spool, then what is t25 then?? Extra super quick! Fool boos way before 3000rpm. Sometimes its a bit tiring.
As far as fitting tsi kit with t28 instead of t25, Turbo Specialties (tsi) kit does not require any modifications (as per tsi), exturbo6 had problem, but it was not due to tsi, but something doe to clutch cylinder.
t28 will be even tighter fit to t25. My t25 intake housing (should've I say compressor side??) is very close to an engine block.
My t25 dyno has full power at about 6000 rpms and t28 will produce power a little further into rpms...
I get very good low end power, car feels as a blast when revved to mid rpms, not as much in 3rd, but in 4th gear I see engine not willing to go to the readline after 6000 rpms (luck of efficiency), but switching to 5th will make car jump into rather brisk acceleration...
Old Feb 9, 2006
exturbo6's Avatar
there is no t28bb turbo...well tsi sells one, i had one.
http://www.streetlevelperformance.co...rbo%20Kit.html
scroll down to the 3rd d17 turbo kit by tsi...and it says this"ALL Honda Civic D17
TSI Extreme Turbo Kit (T28 Ball Bearing Turbo)"
o yeah and i had a t28bb turbo.
Old Feb 9, 2006
HondaLuver's Avatar
Its a celebration bitches!
just get a GT40R, thats what i wanna get...
Old Feb 9, 2006
turboengnr's Avatar
DONT PANIC
GT40... what do you want??? 700whp?
i made 650 at the wheels on an SRT4 with a GT35r with the .63 housing
i just think a gt40 would be a little large for a daily driven 2.4L honda
and no, im not taunting you or anything. its just that you said gt40, and that turbo is the size of my engine
Old Feb 9, 2006
ncirom2003's Avatar
when does the t28 run out of steam if the t25 does at 6000rpm
Old Feb 9, 2006
dipset7's Avatar
I just really wanted sumptin different ya know, not to dis on the t/3-t/4 but they're like mufflers nowadays "everyones got one"!!! I just wanted to do it a little different. I was gonna buy the tsi kit from John Brown for 1650 but got a better deal w/the T28BB for 1500 and $88 to ship. I appreciate all the input fellas.
Old Feb 9, 2006
snooze2's Avatar
snooze2 is an unknown quantity at this point
Is there different trimmings for T25 n T28?
S15 has the T28 as stock turbine... the A/R is 0.8. Can we still use this turbine on ours?? Seems like the HKS site has T25 n T28 in A/R of 0.64 and 0.8 respectively..
Whats the A/R of the T28 from TSI?? Thanks for the info...
Old Feb 9, 2006
I'm not sure what trim tsi has, but I'd think something thats cheaper....
I googled onece a shop and they sell tsi parts for any tsi kit out there, they sold turbos for those kits, and I remember t25 was 450 and t28 was 650
Old Feb 9, 2006
tfnaaf's Avatar
BLDNPSI Mod
GT28R =
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
Turbine
-Wheel: 53mm w/ 62 trim
-Housing: .64 ar
Compressor
-Wheel: 60mm w/ 60 trim
-Housing: .60 ar
Mine was builing max HP @6000 rpm and flat from there at 7psi on a conservative tune. Im thinking it could be do to restrictive DC sport TCS exhaust possibly, or the 2.25" Downpipe
Old Feb 9, 2006
Logan3024's Avatar
Sounds like you dont know to much about t-series turbos. Silvias use a GT28 as a stock turbo, FYI its a DUAL ball bearing turbo, water cooled turbo.
Old Feb 9, 2006
Logan3024's Avatar
http://www.importperformanceparts.ne...-garretts.html
Old Feb 10, 2006
turboengnr's Avatar
DONT PANIC
T-series turbos are the TSO4, T61, T64, T66, T70, T72 and T76 turbos. Not T28 turbos.
Old Feb 10, 2006
snooze2's Avatar
What kinda hp r u pullin at 6000rpm on 7psi? What rpm did the spool start on ur T28R?? Do u think a 2.5" downpipe can solve the challenge?
Old Feb 10, 2006
exturbo6's Avatar
i thought there wasnt any t28bb turbos.....thats what andy said...i guess the genus doesnt know everything..lmao.
Old Feb 10, 2006
tfnaaf's Avatar
BLDNPSI Mod
BTW its a GT28R @ 169.8whp on an auto trans . Im not for sure on the downpipe therory. I mean if you click my signature and look at its pictures its prolly as free flowing as ANY 2.25" downpipe ever made, but im sure it would free up some HP if i went larger
Old Feb 10, 2006
You got it!
It does say they have t28 bb "disco potato"
lol...Info is in his signature...
Old Feb 10, 2006
snooze2's Avatar
Umm... think i m dreamin. saw ur pics b4 already.. haha.. juz slipped my mind there. What rpm does the T28R start spoolin??
Old Feb 10, 2006
I'm confused now and I know I dont know everything.
Why whouldnt t25/28 be included, it does have "t" .....??
Does it mean t3 and t4 are not "t" series turbos as well?
