ok, i found a motor
Old Feb 5, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
ok, i found a motor
ok, so i found a k24 on ebay with under 75k on it. dude is in tennesee, im in GA. i want this in my car. except i have never done a swap. the motor is only 875. i can do this for ALOT cheaper than a turbo.
someone please tell me what im looking at.
how much would labor be to install this thing? i mean how many hours. cause i know labor varies between shops. anyway, here are my q's
1. will i need a new cluster if i get this swap? or are some gauges enough?
2. new tranny if i decide to get the k20a2/k20z1 head? how much would the head run me?
3. new axels too?
4. should i get an type S ecu? or stick with a k24 ecu?
5. can i get a reflash on a k24 ecu?
6. which tranny should i grab? is the k24 accord tranny the same as the type S besides the 6th gear?
7. any other thoughts or suggestions?
Old Feb 5, 2006
Da1lyDr1ver's Avatar
the swap is gonna run you up about $6000 at least if you get it done at a shop.
what happened to your stock motor anyways? it seems like you should do more research before diving into this head first without knowing too much about whats required...
Old Feb 5, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
1. no
2. no. u need a k20 tranny either head u use.
3. yes. either m/t or a/t base rsx or 02+ civic si.
4. get kpro for it to run properly ... depending on which k24 u got, it won't run properly. if u get a k20 head, kpro is REQUIRED.
5. only on the tsx ecu... which I'm sure that's not the motor you're getting.
6. get a k20a2 or k20z1 tranny.
7. more info on what comes with the motor ... which motor is it ... and you're gonna need a shitload more parts to be able to put it in.
k24 subframe won't work.
Old Feb 5, 2006
MajinB's Avatar
i don't think it will run 6k... my stock motor is in my car running fine. and im reaserching right now.
Old Feb 5, 2006
HondaLuver's Avatar
Its a celebration bitches!
eh, remember, nothing in your stock engine bay will fit on the k24.. it will start to add up... especially when you have to buy alll sorts of little parts...
Old Feb 5, 2006
TemjinX2's Avatar
This is a good place to start. It'll give you an idea on prices and good place for research.
http://www.k20a.org/forum/
You also need to get the hasport mounts, si radiator, and blahblah.
Old Feb 5, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
3. new axels too?
7. any other thoughts or suggestions?[/QUOTE]
1. get a type-s cluster
2. type-s tranny (check ur local junk yard) and try to get ur trans misc parts then & there.
3. 02-03Si (4 lugs) or type-s(5 lug) axles, knuckles, brake cylinder, SS lines and new rotors/pads
4. K-pro regardless of wut head. LIke aznboysfr said
5. Get K-pro
6. Type-s^^^ (6 speed)
7. keep K24 header, get Si subframe, Si radiator, Battery relocation, etc... etc
Old Feb 5, 2006
MajinB's Avatar
lets say that in the next few months ill be getting, oh say, around 3k cash. you think that will run me enough?
junkyard stuff is hella cheap.
i want to keep the 4 lug, so i guess ill get the hatch SI axels.
if i have to replace the cluster o well. if not, ill just use some gauges.
i actually found a shop for imports with a dyno near me. im gonna go over in a few weeks and talk to these guys about it. i also have a mechanic here that can do any swap i need. i need to compare labor rates. thanx for the help. im still open for thoughts.
Old Feb 5, 2006
tfnaaf's Avatar
BLDNPSI Mod
get an esitmate for what you THINK it will cost then add 20-50% and that will be your final cost
Old Feb 5, 2006
cubanmike26's Avatar
^^Too much money, time & truble..for that I'd just trade the vic for a Type S and save all the headache
Old Feb 5, 2006
MajinB's Avatar
o well. thats not what i want.
Old Feb 5, 2006
^^I know I know..I didn't mean to discourage you at all..I too want a more powerful engine, it's just that a K20 and everything that comes with it is a freaking hasle imo..
Old Feb 5, 2006
MajinB's Avatar
^^I know..I didn't mean to discourage you from your ideas..I too want a more powerful engine, but it's just a damn hasle imo..
to be honest, i want to do this to learn. i mean, when i wanted to learn about ICE i put a system in my car. when i wanted to learn about cars in general i bought one and did all the work. i want to learn the technical stuff. like tuning. i mean literally tuning on a dyno, swapping motors. stuff like that. when i get my s techs, and sway bar, im gonna learn how to install it all. to me, the information that i learn is invaluble. so yes, it will be a bitch. but to me its worth it. all of it. so when i actually do this, im gonna help the mechanic in every way i can. im pretty sure he won't object, since i am paying his *** for it.
Old Feb 5, 2006
If I had the money and the time for sure I'll do it too..best of luck to you.
Old Feb 5, 2006
then next time u wont need help^^ i feel ya bud
Old Feb 5, 2006
dre2600's Avatar
Who was the member on this site who swapped in a K24 (w. TypeS head? can't recall). Ask him to tally his costs for you.
Old Feb 5, 2006
K20me's Avatar
That would be Hondaluver....he already posted.
Old Feb 5, 2006
MajinB's Avatar
i pmed him about a month ago. never got a response. i can respect that. i can figure it out. i have time.
Old Feb 5, 2006
mrDFWmechanic's Avatar
i would get the K24 and put a type s head on it higher rev's, plus it gets rid of the fly by wire crap. but thats just me
Old Feb 5, 2006
MajinB's Avatar
thats the plan
Old Feb 5, 2006
but thats gonna require getting Kpro and dishing out some extra money but you'll have more power so its kinda worth it in the end
Old Feb 6, 2006
MajinB's Avatar
1.k24 motor 800 bucks- less if i pick it up or junkyard it
2. k20a2/k20z1 head - junkyard 500. ebay~900+shipping
3. type S tranny- 500 ebay~ 800 +shipping
4. k-pro- around 900 bucks. depends on shop. probably less if i pay cash.
5. axels ~200
6. vafc2~300
7. rsx subframe- i don't know
8. motor mounts-idk
9. cluster 80-100 bucks
10. gauges, 40 each +pillar idk how many
11. re-location of a bunch of crap- IDK
if im wrong someone correct me. ill get labor rates when i get a day off. workin 7 days a week sucks but its worth it damn it. maybe ill go up today anyway, see what i can do. any help would be great. thanx yall.
im gonna need the crv ECU. unless the accord one is the same. cause its says on the hondata website it can be used with the crv ECU. it don't say anyhting about the accord
Old Feb 6, 2006
MajinB's Avatar
i never said 3k is my limit. motor mounts are NOT 450...
Old Feb 6, 2006
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
you have no idea what you are geting your self into, but a swap not a long block it will be cheaper in the long run
Old Feb 6, 2006
MajinB's Avatar
thanx for NOT helping. i don't care wtf you all think about it. i asked for help. im obviously not gonna get it. itbl
Old Feb 6, 2006
CenZ's Avatar
PWIT
hey i know you said you found a motor and everything, but check this out. its a k20a2 complete swap, motor tranny ecu harness take a peak. http://cgi.ebay.com/ebaymotors/K20A2...spagenameZWDVW
Old Feb 6, 2006
Supercharged k20a3
if you want help this is a perts list from hasport
http://hasport.com/News/Articles/ESK1parts.htm
Old Feb 6, 2006
CenZ's Avatar
PWIT
oh found another that looks like it comes with more, but its a k20a3
http://cgi.ebay.com/ebaymotors/05-HO...spagenameZWDVW
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Supramk3
May 11, 2015 07:55 PM
hokiedad4
May 3, 2015 10:06 PM
mievil
Apr 28, 2015 11:02 PM
tylerginevan
Apr 27, 2015 12:29 PM
