new si engine in a 01-05 civic
Old Jan 10, 2006
boricuachulo's Avatar
boricuachulo is an unknown quantity at this point
Question new si engine in a 01-05 civic
a question.. will the new SI engine fit in our 7th gen?
Old Jan 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
fit? yes.
work? ... probably not.
the new Si's are drive by wire ... even if you could run a throttle cable with the t/b, you'd need a throttle cable driven ecu.
-_-;;;
Old Jan 10, 2006
you think someone will do it?
Old Jan 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
until someone figures out dbw, you'd probably have to use a 2002-04 rsx-s ecu and use kpro to tune it. even then, you're gonna throw a shitload of cel codes due to the whole car being different.
Old Jan 10, 2006
tfnaaf's Avatar
BLDNPSI Mod
im sure it can be done, why not just convert it to normal TB and use a stand alone ECU?
Old Jan 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
and which ecu would you use?
Old Jan 10, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
You'd need a K-pro, you'd also need to modify the IM to work with a cable TB. There's stuff floating around the K series websites about using the IM because of the short runner design. Do some searching on K20a, K-series, etc....
Old Jan 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yes, but ... you can't kpro the 05+ rsx ecu ... you can't k-pro the 06 Si ecu (yet)
the 06 Si ecu is what you're gonna need to run your car and all the little sensors ... otherwise you'll have a massive flurry of CEL's.
at least that's what I would think.
Old Jan 10, 2006
tfnaaf's Avatar
BLDNPSI Mod
then why not run an 04 ecu ?
Old Jan 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I'm sure there are many differences in how the Si and the rsx operate as I said a million times. that's what I don't think it would work.
Old Jan 10, 2006
Jap-Euro Fusion
Sooner or later, hondata is going to sort it out. Just give it time.... Kpro took a while to do the first time.
Old Jan 10, 2006
4bangin's Avatar
I think in the new Honda Tuning mag (January or Feburary issue) they have a whole section of new Si's that companies did up for SEMA or some **** and a couple of the companies used K-pro.
Old Jan 10, 2006
vietrice507's Avatar
vietrice507 is an unknown quantity at this point
yes it will work but you hav to get 02-04 RSX ECU then k-pro ,TB thats all i can think of for now
Old Jan 12, 2006
this is good. keep it up. will like more information on this swap
so TB will be a problem?
Old Jan 16, 2006
fastest_ex's Avatar
fastest_ex is an unknown quantity at this point
i think it would have some fitting issuses, first the motor is mounted differently, and its has an rbc IM which won't fit in our chassis cuz i'm have trouble fitting it on my k20....rad. support is too close to engine....and i'm sure there will be other issues..its just better to stick with the basic's and get an 02-04 type-s engie and mod it from there!!!!!
Old Jan 16, 2006
yes you hav to cut the radiator support a lilbit that s what i heard for the RBC IM, im in the pogress of K24 and K20Z3 head swap ill let you guy know when im done
Old Jan 17, 2006
drjvic04's Avatar
drjvic04 is on a distinguished road
Does the engine even turn the same way?
From the pics I saw of the engine bay if looked like the IM and Ex man had switched places.
So you would need the complete engine and trany assembly. Thats a lot of work for 197hp.
Old Jan 17, 2006
TheSmuggler's Avatar
I'm sitting here staring at the screen wondering why you would want it? Perhaps you'll say it's k20 powa! Well then go buy a k20a2, it works, we know, nuff said. Maybe you'll say but SMUG it has LSD, well go mate your k20a2 to a k20a tranny...
Old Jan 17, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hehe ... do you know how much k20a trannies cost?
Old Jan 17, 2006
HAHA I know man, but like they say where there's a will, there's a way...
http://store.yahoo.com/yhst-14083816...indc5tyrl.html
and if you absolutley must have shorter GR's, which I coulda do without...
http://store.yahoo.com/yhst-14083816...intyr4fid.html
But I digress.. whats the going rate on the whole tranny now?
Old Jan 17, 2006
CarbonFiberSi's Avatar
CarbonFiberSi is an unknown quantity at this point
If the new Si is anything like the TSX then the drive by wire throttle is simply a normal throttle cable from the gas pedal to a box mounted on the passenger side under the engine bay. It then gets converted to an electronic signal from there. Think of it along the lines of cruise control. So for a TSX swap, all you need is an RSX throttle body and throttle cable.
Not sure on the new Si though but with any luck it will be the same.
Old Jan 18, 2006
nice keep it going.
Old Jan 18, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
06 si is as good as 04 k20, but with LSD (!)
Probably you already know this, but I still want to get to the bottom of this.
Dropping 06 si engine you will get same ~200hp as k20, and you will have bigger bill to pay. At least the real advantage not seen here.
Whats you reason to take 06 k20 over 04 k20 ??
Old Jan 18, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I take it back ... I don't believe the 06 Si engine would fit due to the intake manifold.
I took a look at some pictures and the RRB/RBC intake manifold is much longer than the PRB/PRC ... it will probably hit the metal core support (or whatever it's called) in front.
if you change out the intake manifold, then it will probably fit.
Old Jan 19, 2006
so it's doable?
Old Jan 20, 2006
It will fit, but a lot of custom work be needed
Old Jan 21, 2006
I'm still stupifyed on WTF you would even WANT to do this...
Old Jan 21, 2006
5 speed automatic or even 6 speed automatic
Old Jan 22, 2006
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
haha.. theres always a way... Maybe not now but there will be some one.. For one thing,. I dont knw how the F*** is any one going to find an 06 Si engine for sale. You can hardly get the actuall car right now..
I'am going to have to order mine.. because everytime i go to Honda it either comes in a color i dont want, or its sold before it even gets to the lot..
Hopefully my **** will be here in 2weeks.. I wanna see the true power in that little beast!haha
Old Jan 22, 2006
ricers will start wrecking those left and right. just make friends with the junkyard guy and have him call you when a new arrival comes in.
