Fab guys... did anyone use an exhaust flex section?
Old Jan 5, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Did anyone actually have to use one?
Just wondering, I've gotta hack the DP in front of the cat and weld it on, I know the flex section buys some fudge factor, but they tend to be the first thing to blow out when the exhaust goes. I'd much rather just weld it together pipe to pipe.
Also, anyone reciently measured the diameter of the stock DP and know offhand what it is?
I'm working on my stock order for charge pipes and exhaust...
Old Jan 5, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
i didnt have one at first, but when i got my new downpipe made, they put one in and i noticed a world of difference. the steering wheel used to shake alot before and with the flex pipe it didnt at all. there is alot of pressure going through the exhaust system and having a little room to bend and flex with the pipe allows it to adjust.
Old Jan 5, 2006
andyman97's Avatar
Turbo Guru
Yeah, I never used one before, either. I couldn't say a difference because I haven't put one in but, over time, I have noticed that my manifold bolts/nuts want to back out and so do my downpipe bolts. I will definitely be installing one once I start installing my next set of parts.
Old Jan 5, 2006
Jap-Euro Fusion
well it sounds like the right plan is to include one then...... I'll tack it onto the parts pile.
Old Jan 5, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
yeah Id get one man, I've seen downpipe and manifolds crack in long term situations. I would say it would be a cheap investment to put one one there.
BTW Justin your inlet flange is done and I just hafta finish the brackets on that intercooler when I get a minute. That inlet flange came out great too.
Old Jan 5, 2006
Jap-Euro Fusion
Awesome..... I look forward to seeing done stuff.
Old Jan 5, 2006
Spoolin's Avatar
spoolin by you
as far as how big the stock dp is, i dont know that for sure, but i do know that the stock exhaust is 1.5" and the downpipe is bigger then that. so, i would guess it is maybe 2" possibly...
Old Jan 6, 2006
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
im running the flex pipe... had megan dp with sf turbo before and it cracked for only 5k mile of use.
fyi, megan is straight pipe, and theres no flex in there.
Old Jan 6, 2006
HondaLuver's Avatar
Its a celebration bitches!
get 1 man, i have ripped 2 out, the exhaust and engine move around alot.. its some good cheap insurance you don't have to replace the whole exhaust mani
Old Jan 6, 2006
Logan3024's Avatar
Heres my setup 2.5" 8" flex pipe
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
