diy on return fuel?
Old Jan 3, 2006
mskatingd's Avatar
mskatingd is an unknown quantity at this point
diy on return fuel?
enyone else not gettin the pics or is it my comp
Old Jan 3, 2006
tfnaaf's Avatar
BLDNPSI Mod
for what thread? i have some on my signature
Old Jan 3, 2006
mskatingd's Avatar
7thgencivic.com/forums/showthread.php?t=140975
Old Jan 3, 2006
tfnaaf's Avatar
BLDNPSI Mod
you could try PMing opto_isolator he may still have the pictures, if not i have those on my signature i had saved that post of his in a file but for some reason it only saved one picture
Old Jan 3, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
whats the estimated cost on doing a return fuel conversion if you do it diy?
Old Jan 3, 2006
tfnaaf's Avatar
BLDNPSI Mod
Depends on the quality/grade of parts you use and what it cost you to have a bung welded onto the fuel rail. i imagine you could do it for a couple hundred dollars.....
pump =$100
modify fuel rail = $40-50 ( tig weld bung to rail )
20' approx an-6 hose with clamps/fittings = from maybe $40-200 (depends on what you use and how extravagant it is)
pressure regualtor = $75-150
optional pressure regualtor = $20
im prolly missing something but you get the idea
Old Jan 4, 2006
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
see if this page will help you out.
http://myweb.cableone.net/tfnaaf/index.htm
Old Jan 4, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
tfnaaf
Thats your project page!
Old Jan 4, 2006
PrecisnTec's Avatar
Originally Posted by 03-Acura-1.7-EL
tfnaaf
that's probably the link on tfnaaf's signature, I just have sigs disabled while i'm at work and knew I had his link book marked.
Old Jan 4, 2006
tfnaaf's Avatar
BLDNPSI Mod
Old Jan 4, 2006
mskatingd's Avatar
that'll work thx ptec
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
