New Piggyback ECU that yielded GREAT results
Originally Posted by tfnaaf
I like the target AFR feature. If this works as good as it sounds i can for see a lot of these on boosted D17's
doesnt the Emanage Ultimate do this already?
To be honest i have no idea, ive never read about the ultimate much
7thgen Power Maker
7thgen Power Maker
Originally Posted by 02LX
I plan on doing a head swap on my lx, and was going to use the vafc hook it up, how can this system work for me? In other words, will it work on the my LX ecu?
PC Tech / Autocrosser
So Dezod, why would you suggest this piggy back system over e-manage? Besides it being able to overcome complex ECU's, which would would benefit me more if I am going with a low boost, small turbo application? (6 - 8 psi on a t25)? and why one over the other?
7thgen Power Maker
Originally Posted by boricuachulo
very interested in the product. i already tune my ECU. will that be a problem using the product (2004 ex coupe-headers,intake,cat back and ecu up grade)
7thgen Power Maker
7thgen Power Maker
Originally Posted by Michalo187
So this one won't have problems with bigger injectors and getting them to idle and it will also not be over ridden by the stock Ecu?
Im wondering this myself. I've looked over the program and i dont see a injector correction screen. With further reading the product info it implies that you compensate for the bigger injectors with the map/maf scew map so it seems that it would require more tunning across the full spectrum but i could be wrong
7thgen Power Maker
Originally Posted by turboengnr
Since this is all done with the MAP skew feature, am i safe to assume that this unit does not intercept and modify the actual signal to the injectors?
7thgen Power Maker
7thgen Power Maker
wouldnt modifying the map sensor signal bring up the same baro ECU code as the emanage?
I know personally the ECU has a certain level of variance it will tolerate at idle and closed loop operation. I have pushed and tested the boundaries personally......
dezod have you ever heard of perfect power? they make several different kinds of units as well. they make anything form basic piggy backs toi more extensive ones to stand alones. they have a good unit called the smt7. it is a piggy back check them out and tell me what you think. it has full ignition control as well
http://www.perfectpower.com/products/smt7.asp
when is the ignition control for PCS due to come? in close loop, will the ECU totaly ignore the signals from the emanage or ultimate? would that cause me to lean out and blow my engine if im in boost in close loop?
7thgen Power Maker
The PCS replaces the e-manage. Not sure what your asking here. If you do not know what your doing, you cna blow your motor even with an e-manage. So I recommend professional tuning.
i learned that the ECU will overide or overcome the signals from the emanage. ultimate likewise? is it substantial as in a complete overcome of signals? so will in that case the singals or tuning from the piggyback will be of a total waste or what? that is during close loop ops? and if so happens i boost during this phase will it lean out on me and cause me to blow up.
7thgen Power Maker
My question is how well will this work, will it be a constant UP and dOWN of AFR that will varry drastically? or will it be min amount of fluxuation as in +- .5 afr ? Right now i have mine tuned pretty damn close as to where the long term fuel trim varries VERY little
Originally Posted by dezod
The ECUs now a days, relearn some of the closed loop tunign through O2 sensor feedback, PCS overcomes this through O2 sensor skew.
7thgen Power Maker
01civyv3
Jun 2, 2015 05:21 AM
beveragemp
May 25, 2015 07:11 PM
dooner24
Apr 14, 2015 07:51 PM
CapYoda
Nov 29, 2001 07:37 PM
