Different K20's
Old Dec 31, 2005
  #31
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Originally Posted by xproductionz
k.. check this out....
then explain this to me..
why is it that the base rsx and civic si have
9.8:1 compression
2 intake lobes and
1 exhaust lobe
puts out what about 160hp
then why is it that the jdm type s is
9.8:1 compression
has real vtec on the intake side of 3 intake lobes
1 exhaust lobe
and puts out the same hp of 160...
so the jdm type s has real vtec on the intake side yet has the same hp as the USDM... why waste all that money????
hey thanks. You just further proved my point. You are essentially asking the same question there that I'm asking. See:
Originally Posted by aznboysrfr
Frankly, I don't see why USDM Base RSX's are still rated at 160 HP since they don't have 3 lobe vtec on the intake ... as far as I know. They should be rated at 155 HP or so
Good question though. Why did you waste $2800 on a jdm type s motor that is rated with the same HP as the base rsx/civic si?
Specs are right there, plain as day on the honda japanese website.
A K20A2 head on a K20A3 block is going to make more potential power that a jdm type S motor due to the 3-lobe on the exhaust. It would be cheaper to go that route too.
drivetofast/josh spent $1100 on a complete k20a3, minus subframe. $900 head and you have something better than a jdm type s swap.
Old Jan 1, 2006
  #32
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
I'm seriously considering buying a k20a3 later on and supercharge it, let's see...
Old Jan 1, 2006
  #33
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
well if you must know... for one the block does have individual oil squirters for each cylinder like how the k20a2 has.. the k20a3 doesnt have em so thats one of the benefits... the other thing is that i got a k20a2 head out of the deal so it was no biggie.. $2800 for a complete jdm type s swap with a complete k20a2 head... plus right now i am rated at 201hp on the dyno with intake header exhaust and kpro so you dont hear me complaining about what the stock number hp is supposed to be
Old Jan 1, 2006
  #34
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I don't not believe you, but how do you know the block has oil squirters?
well ... I guess 1/4 mile times will only tell. Again, I don't not believe you, but there have been a lot of people who bring out inaccurate or false information...
Old Jan 1, 2006
  #35
Hayz's Avatar
good info
Old Jan 1, 2006
  #36
i had to change my oil pan cause the one that shipped with the motor was cut open... obviously how else would i know... want me to open the bottom of my block once again to take pictures... i was curious where i got this motor just as much as anybody... and what specs it was.... based on that i knew that it had 3 intake and 1 exhaust lobe... oil squirters... and a compression of somewhere between 11 and 11.5 based off of volume tests.. not compression tests..because obviously nobody believed me when i said i had 3 intake cams and 1 exhaust cams... now they have actual documentation and i took pictures... dude i own a shop and been working on this motor since i got it.. basically your saying i dont know my own motor
how does 1/4 mile times have to do with the oil squirters?
Old Jan 1, 2006
  #37
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
1/4 mile doesn't have anything to do with oil squirters. it was an unrelated question.
I don't want you to open it up. I believe you ...
but as for having 11.5:1 compression ... that's something that I still cannot believe. both of us know jdm type s motors don't come with 11.5:1 compression unless someone swapped out the pistons, which I highly doubt would happen.
Old Jan 2, 2006
  #38
4*banger's Avatar
4*banger is an unknown quantity at this point
alright, i just read all 3 pages and id liek to know Xproductions, your K20 as the 3 lobes instead of 2, so does it engage in Vtec (i-VTEC) or VTC just like the usdm 160hp k20? and also do you have to lose a/c and power steering to fit in the K20?
Old Jan 2, 2006
  #39
yes technically me and you both agree that by OFFICIAL SPECs based off there website it does state it to be 9.8:1 compression and that what i thought it to be..
i was skeptical soooo
as for my motor having 11:1 - 11.5:1 compression is what gets me... remember that they did volume tests on the block... volume tests determine the type of compression unknown pistons have... which came up to be 11 something... but for a volume test to be that much off from a 9.8 to a 11 something is far to off
Old Jan 2, 2006
  #40
armieo's Avatar
< My future wife.
confuzzled.
Old Jan 2, 2006
  #41
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
okay. I've already read quite a few times that you did volume tests on this and that other thread alone. However, you still fail to provide proof of them, as you did on clubrsx as well.
Old Jan 2, 2006
  #42
4*banger's Avatar
??? would someone liek to answer?
Old Jan 2, 2006
  #43
CivicsRdBest's Avatar
Hmmm... I always thought the JDM type-S was just the base RSX here... I guess I've been proven wrong.
interesting... like everyone else I guess, was the extra lobe/cylinder worth it?
Old Jan 3, 2006
  #44
4*banger's Avatar
does the extra love make it engage in full vtec? or is it VTC like the base rsx?
Old Jan 3, 2006
  #45
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
all i-VTEC motors have VTC.
read: http://www.hondata.com/techk20general.html
Old Jan 3, 2006
  #46
02civicricer's Avatar
The Rice Machine
02civicricer is on a distinguished road
Originally Posted by ragingSPAM
if you want the japanese site the JDM integra Type-S here is the link
http://www.honda.co.jp/auto-lineup/integra/
you can rep me now or later hehehe
kind of off-topic but did anyone notice that the integra in the pic had new york plates on it. My point being that this is a japanese honda site for japan. lol!
Old Jan 3, 2006
  #47
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
good find. check rep
Old Jan 3, 2006
  #48
thats the thing... i was in the process of moving into my new house when i did the tests... so i lost alot of things.. a few parts.. and some paperwork.. they must be in one of my boxes that i have yet to unpack (its been sitting a while.. lol)... heck while i was looking that i was also trying to look for my dyno sheet which i cant find anymore.. but i am planning to pull the block again to put in some new stronger rods and pistons so when we do that i'll get some volume tests done again if i cant find the original paperwork then
justcruzin125
Aug 11, 2015 09:09 PM
Inkubus
Bolt-on Engine Performance
Jun 30, 2015 12:11 AM
tRu
35
Sep 16, 2005 05:11 AM
kenji4861
Dec 29, 2002 01:55 PM
Freshguju
98
Nov 11, 2002 10:09 AM
