Turbo Coolent Line Help
Old Dec 26, 2005
ajhdragon's Avatar
7thgens official a$$hole
right now i have the coolent lines ran where i basically rerouted the coolent to run through the turbo before back to the engine. Ive seen pictures where it looks like the water pump is tapped with a steal braded line. And i went out and looked at the pump and there is a internal thread on the pump where it looks like other people on the site tapped. My question is is this the right place to tap a line? How do you go about tapping it just a regular tap? And where do you have the coolent going back into the engine? I would really like to know how people have their coolent lines ran becasue it looks so much cleaner. Pictures would be a great help if possible.
Old Dec 26, 2005
ajhdragon's Avatar
BTW im running a garret T25bb, do i even need to run water through it? ive heard you don't.
Old Dec 26, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
you're just looking for a cleaner install look or more functional?
Old Dec 26, 2005
ajhdragon's Avatar
a little of both i suppose. Ive heard you don't need to run water through the turbo. i have a problem with a leak right now thats why im wondering. before i spend money to fix a leak and then find out how to make it cleaner and nicer and have to spend even more.
Old Dec 26, 2005
ajhdragon's Avatar
btw im kind of a turbo noob, im more fimaliar with superchargers and all motor applications from my muscle car days.
Old Dec 26, 2005
XSRCivic's Avatar
water cooling is a plus for reliability and life of the turbo but many turbos are non water cooled. This particular turbo on the other hand might have been desinged to be water cooled and might not last as long without it.
Quote from a website:
"Turbos with watercooled bearing cartridges have a protective barrier against cooking. The water boils in the cartridge when the engine is shut off and forms a natural recirculation to drain away the heat"
You know too much heat is bad for a turbo motor.. this just aids it.
Old Dec 26, 2005
ajhdragon's Avatar
kool thanks, i just im'd eyeseeyou. i know he had the TSI kit. that comes with the t25bb maybe he can help me out.
Old Dec 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
click on my signature and there are some pictures that show where i hooked mine up. One end to the TB and the other one to the end of the cyl head
Old Dec 26, 2005
ajhdragon's Avatar
we have basically the same setup and from what i can see your not useing any water coolent?
Old Dec 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
SORRY for the huge picture but oh well!
Look at the Throttle body there is a SS line with a red clamp on it. And on the end of the cyl head there is also a SS line with a red clamp. These are 2 seperate lines that run down along the trans and then over and up to the turbo
Old Dec 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
here is a picture from belwo where they enter the turbo
Old Dec 26, 2005
ajhdragon's Avatar
gocha man thanks for the help. looks like thats what im doing this weekend.
Old Dec 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Just another suggestion, its a relatively blingtastic way of doing it but should be quite effective.... buy 2 greddy (or generic equivelant) water hose sensor housings, and 2 1/8 BSPT to NPT converters and a pair of 1/8NPT to barb or -6 adapters (yes, lots of adapting, but I've never seen a BSPT to AN adapter, NOTE generics may already have the NPT threads, if so, skip the BSPT/NPT converter), and put one in each radiator hose. Just loop the turbo between the radiator.
Coolest possible water in, and you dump the hot stuff right back into the radiator.
Old Dec 28, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
With TSI you need to tap into 2 heater core antifreeze lines.
TSI gives you 2 T links and 2 mettal/rubber lines to screw to the turbo.
The pic shows where I had to cut heater lines to use "T" for the turbo. Easy.
Thanks tfnaaf for the good quality image!
HondaGuy7
Feb 22, 2016 01:00 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
