Nitrous Install Pics
Old Dec 23, 2005
speedster's Avatar
speedster is an unknown quantity at this point
Just thought I'd show everyone what I've been up to the past month. Thanks to everyone who helped me with my questions and your patience with me. I know some of you got discouraged with me on some of my posts. This was my first nitrous install on a fuel injected car and I just wanted to take every precaution I could. Anyway here's some pics.
Old Dec 23, 2005
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
From what i could actually see, it looks pretty decent. But the damn pics are soooo small.
Old Dec 23, 2005
four twenty's Avatar
four twenty is an unknown quantity at this point
yeah looks like he did the thumbnails only, maybe on accident?
Old Dec 23, 2005
speedster's Avatar
Sorry for that. It's fixed now. Pics are bigger.
Old Dec 23, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
nice install.... I really like it
Old Dec 23, 2005
disturbed24st's Avatar
disturbed24st is an unknown quantity at this point
Hey speedster what part of TN are you from the background in the first pic looks vey familiar.
Old Dec 23, 2005
vietstylez's Avatar
those relays arent for nitrous are they?
Old Dec 23, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Very clean install. I like it a lot!
I wish my turbo install whould look as clean.
Well done.
Its dyno time now!
1 chart without nitro
1 chart with nitro
Old Dec 23, 2005
sexyness
Old Dec 23, 2005
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
looks sweet!
Old Dec 23, 2005
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
I can just see what would happen in so cal...Officer: "What modifications have you done to your engine?" After he makes me pop the hood. Looks sick very nice!!
Old Dec 23, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Did you hit the button yet?
Old Dec 23, 2005
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
ya post some dynos foo!
Old Dec 23, 2005
speedster's Avatar
Where do I start.... I'm in a place called Sykes, TN. It's in Smith County. Yes all those relays are for the nitrous. Let's start with the one closest to the battery. The first one powers the fuel and nitrous solenoids. The second is for the purge solenoid. The third is for the window switch. The instructions for it said it would only supply a ground up to 1.5 amps. I didn't know if how many amps the solenoids pulled, so I ran a relay for that part of the window switch. The fourth is for the bottle heater. Yes, I have sprayed it several times with the 35 shot. I only sprayed it twice with the 50 shot and on the second time, my check engine light came on. I assumed it was because it was a rich mixture because I didn't have a bottle heater and it was like 30 degrees outside. So I got the bottle heater, electronic nitrous pressure gauge and the wideband a/f ratio gauge. Right now i'm waiting on a set of Denso IK20 plugs because I was told not to run the autolite coppers I had in it for the nitrous. Someone on here told me Autolites suck in our cars. As far as a dyno run, there's not one close by here for cars that I know about. There's one close by that I ran my bike on, but that's about it. Thanks for all the comments
Old Dec 26, 2005
allmotor's Avatar
nor cal 7thgens
i ran a full bottle of 50 shot with the stock plugs and even with 91 oct it ran like **** so ur deff smart for gettin new plugs
Old Dec 26, 2005
show0and2go's Avatar
show0and2go is an unknown quantity at this point
Taht looks Very clean, when GRD (in chicago) installed mine, they did a terrible job. I let it slide, but I just recently uininstalled it and went back to n/a. I loved it, but wish it was a cleaner set-up. congrats!
Old Dec 26, 2005
speedster's Avatar
When I sprayed it my only complaint was that it hesitated a little before you could notice it. I guess it was running rich every time I used it. With the pressure gauge and the wideband, I'll be able to really tell what's going on. I can't wait to get those plugs in.
Old Dec 26, 2005
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
sweet setup, very clean
Old Dec 27, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Is that MSD window swith box, or a launch control box? I want nitrous!
Old Dec 27, 2005
speedster's Avatar
It's a window switch. Turns on at 3000 and turns off at 6200.
Old Dec 27, 2005
scansel912's Avatar
Hmm 3000 RPM's seems a bit early. You are probably running a little rich at 3000 RPM's which could be cause for a delay. Theres a slight delay on mine from when I hit the button but I like it because it gives me time to get my hand back on the shifter to shift cuz when you hit it in first, you're at 7000 RPMs real quick.
Old Dec 27, 2005
speedster's Avatar
You spray in first? Mine spins alot in first since I put in those motor mount inserts. I tried in second and third. I thought about gettting a 3500 or 4000 rpm pill for it. What rpm do you start at?
Old Dec 27, 2005
scansel912's Avatar
Can you give me a link to those motor mount inserts. I think mine are going bad and was wondering how difficult it is to install them and what not.
The only time I spray is when I drag race at our local track. I spray as soon as I catch traction from my launch which could be anywhere from 3500-5000. I would put in the 3500 pill and see how that feels. Spraying at 3000 I would be worried about nitrous detonating in your Intake Mani and blowing it up which happens when you spray too soon.
Old Dec 28, 2005
speedster's Avatar
I got the inserts off ebay. I only paid like 25-30 bucks for them. They're made by Energy Suspension. I only installed the front ones. At first I installed both front and rear, but the vibration was so bad, I took the back ones out. Here's some on ebay, but act fast, there's only 8 hours left on them. Thanks for the advice on higher rpm activation. I'll get some higher rpm pills. Here's the link.
http://cgi.ebay.com/ebaymotors/MOTOR...24326365QQrdZ1
mistermenphis22
Apr 3, 2016 08:06 AM
S.Klinck
Feb 10, 2016 02:19 PM
crowtoo
May 11, 2015 06:50 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
ImmortalEX
Nov 8, 2001 09:52 PM
