K20 Swap Problem.
Old Nov 18, 2005
ImportRacer2123's Avatar
K20 Member
K20 Swap Problem.
Hey Guys I have a Little Problem... My car runs great but from 4k to 5900 it stumbles and falls on its face. but from 6k to 7200 it pulls. Anyone know what my problem could be? I had AutoZone Scan my car and it came back with P1166... So I had my friend who did my wiring come over and fix it by adding a relay. But it stil Stumbles and i have a CEL. Could it be cause im running a Type S O2 Sensor on an a3? Or that im only running a Primary O2 Sensor. MY Mods are
AEM CAI
DC race header
K100
HOndata IMG
Apexi World sport.
Old Nov 18, 2005
CivicSF's Avatar
CivicSF should not be trustedCivicSF should not be trusted
check injector sizes / applications, fuel maps?
(if not sensor problem)
Old Nov 18, 2005
K20 Member
Injectors are 310cc... Applications? Fuel maps? I dont have K-pro...
Old Nov 18, 2005
HondaLuver's Avatar
Its a celebration bitches!
if its a si engine, you have to run the si 02 sensors, if you have kpro, it shouldnt' be a problem, im not sure what that code is... get the right sensors
Old Nov 18, 2005
K20 Member
alright I will.
Old Nov 18, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
why are you using 310cc's when the k20a3's use 240?
I hope your car is tuned for it.
Old Nov 18, 2005
K20 Member
i had to buy and Intake Manifold and well they came with the Intake manifold could that be my problem?
Old Nov 18, 2005
Sick Cycle's Avatar
if you're running 310cc injectors when the stock computer calls for 240, then you're gonna have a problem.
unless your k100 is already tuned for a k20a3 motor with 310cc injectors.
Old Nov 18, 2005
CivicSF's Avatar
you gotta make sure every single part on that motor is correct. that's the only insurance you have that the motor is setup for max power and max reliance. do you have a spec sheet on the appropriate part numbers you need for your engine, etc? check your equipment vs. the swap DIY lists, etc.
Old Nov 19, 2005
civiclx4dr's Avatar
civiclx4dr has a little shameless behaviour in the past
do you got the part # for the relay, im throwing the same code and swapped the a3 so let me know how u fix that and does your car rattle like a bitch between 1500 rpm to 2500 rpm?
Old Nov 20, 2005
K20 Member
yeah its the motor mounts that make the vibrations.... also there uis no part number is just a universial relay that you can buy at shucks... My Problem is stil there but now stumbles at 5k instead of 4k... i think my 05 Type S o2 primary is bad.
Old Nov 20, 2005
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
It might be the sensor since it's a3 and you're usin a type s sensor...my friend ran into the same problem and it's fine now..
Old Nov 20, 2005
K20 Member
Did your friend use an older type s o2?
Old Nov 20, 2005
jeez why can't stuff ever work? so what is the code for? the primary 02 is the only one for a/f so maybe its bad or just not the right one. you mention dc race header, does it have a bung or did you have to make your own.
Old Nov 20, 2005
K20 Member
a bung.....capped off
Old Nov 20, 2005
what i'm trying to say is the sensor in the right spot on the exhaust system?
Old Nov 20, 2005
K20 Member
ya it is... its on the first Bung.
GritzNGravy
Aug 19, 2015 03:03 AM
Kyle Cargazm
Jul 16, 2015 02:06 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
