lx power
Old Nov 15, 2005
GDM LM1's Avatar
GDM LM1 is an unknown quantity at this point
lx power
Sorry if this is a repost whats the power out put of the LX motor on boost and what are some of the pros and cons on boosting this non vtec motor
Old Nov 15, 2005
dezod's Avatar
7thgen Power Maker
LX is quite boostable because of the lower compression. As much as VTEC and turbo are good, I have seen VERY impressive numbers come from the LX turbo'd.
Old Nov 15, 2005
iamboo's Avatar
Retired - SoCal FI Mod
pro: lower compression motor...
con: the EX vtec motors have consistently had about 5-10 more hp on the dyno with turbo than the non vtec lx motors.
Old Nov 15, 2005
GDM LM1's Avatar
Im just looking to make 170-180 to the wheels My Fiance is building the High HP Honda
Old Nov 15, 2005
civic01vtec's Avatar
That is easily obtainable
Old Nov 15, 2005
Michalo187's Avatar
Abortion Survivor
My car is an lx but i did the ex head swap i think that is the best think to do because you get v tec and lower compression. Plus the lx tranny gears are longer i believe. Yeah you could get 180 whp pretty easy
Old Nov 15, 2005
White0nGold's Avatar
White0nGold has a spectacular aura aboutWhite0nGold has a spectacular aura about
i plan on boosting my LX A/T, 4dr, hey Michalo187, how much was ur ex motor swap?
Old Nov 15, 2005
Michalo187's Avatar
Abortion Survivor
Well its no price really. Its what you can find and where you can find it. A head here typically goes for 200 plus shipping if your lucky you can find a good deal. Then you need a emanage or a vafc to control the v tec. Pm me if you need help or have any questions
Old Nov 15, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
peep my sig, i have an lx
Old Nov 15, 2005
Michalo187's Avatar
Abortion Survivor
yeah those are some good numbers from an lx. hopefully by next week i will have good numbers because i am going to buy the aem ems
Edit: O i just realized my first post on hear i said Motor swap i swapped the head. my bad hahahahaha i don't know what i was thinking
Old Nov 16, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
I thought swapping the head would raise compression?
Old Nov 16, 2005
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
headgasket size and how far you mill the head will play a big part in raising or lowering compression
Old Nov 16, 2005
Nope.......the head has nothing to do with compression, unless you mill the head in which will give you more compression.
Old Nov 16, 2005
iamboo's Avatar
you could always stack headgaskets on top of each other... you'd have to torque them down pretty often but that's an alternative to lowering commpression on the motor... lol
Old Nov 16, 2005
jackburton's Avatar
So when you put a k20 head on k24, the compression stays the same?
Milling the head raises the compression? I do not get it.
I think I get it now.
Old Nov 16, 2005
turboengnr's Avatar
DONT PANIC
the thing that changes the compression ratio on the head is the physical size of the combustion chamber.
If the combustion chamber on the new head is smaller than the one on the old one, then you will raise the compression. The Inverse is also true.
Now, i am not sure about the K20 and K24 head, seeing as ive never seen the combustion chamber on a K24. But i do have both EX and LX heads sitting in my garage. They appear to be pretty much identical (besides the fact that the EX has an EGR valve and a Vtec system). I do not think that swapping from an LX to an EX head will yield a considerable change in compression.
But i do have something to say about doing the swap.
You really should use the EX computer when you do the swap. The fuel trims and ignition timing for the LX is set up for the LX cam profile. The EX ECU sets up the fuel trims and ignition timing for the ex low-vtec and high-vtec cam profiles. If you use the LX computer with the EX cam, you will have too much fuel at some points, too little at others. And you will have too much timing at some points, and too little at others.
You can tune all of that out, but if you just start with it right, then that is less tuning you will have to do since you are already starting at on higher grounds.
Old Nov 16, 2005
Slow Gold's Avatar
i wonder why the lx has a differant EGR then the EX ive also noticed this.
Old Nov 16, 2005
turboengnr's Avatar
DONT PANIC
the lx doesnt have an egr
Old Nov 16, 2005
Slow Gold's Avatar
i wonder why the ex has one and not the lx
Old Nov 16, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
This is my LX engine.
Before internals I was pushing 180hp on nitrous.
After internals we hit 223 with turbo and e-manage.
My goal is 250hp with AEM EMS.
My tuner was quite impress how the D17 was taking a lot of punishment on the dyno and posted good numbers.
Old Nov 16, 2005
turboengnr's Avatar
DONT PANIC
supermex......
where did you get that additional injector holder? I have been looking at different ones, and i am in need of 4 of them.....
the closest thing i have found to what i need is $64 each.
Old Nov 16, 2005
jackburton's Avatar
I understand that by milling the head you can raise compression. I also understand that compression has to do with the size of the combustion chamber, that is why lower compression pistons have dips in them.
Now I do not understand why the compression on the d17a1 is lower than a2 if the head is the same. I would appreciate any input, I feel like an idiot.
Old Nov 16, 2005
supermex's Avatar
Originally Posted by turboengnr
supermex......
It was welded at the shop.
The guy had it in his tool box.
Old Nov 16, 2005
turboengnr's Avatar
DONT PANIC
damn.... o well.
ok. lemme do a quick explanation of compression.
lets say that at BDC (bottom dead center) your cylinder holds 10 cubic feet of air. Then at TDC (top dead center) your cylinder holds 1 cubic foot. That means that your compression ratio is 10:1.
The difference between ex and lx is in the piston.
Old Nov 16, 2005
jackburton's Avatar
Thumbs up
Thank you very much, very informative as usual!
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
