sf NEW fmu install
is it alright to just power and ground it and put a switch on the power and turn it on whenever your gonna boost, in your opinion...then switching over to a hobbs later on?
i really dont go into boost that often.
DONT PANIC
dont put a manual switch on it. Just hook it up to an ignition source and a relay to turn it on for now, then you can swap to a hobbs switch later.
it only takes 1 forgetful moment to break your car.
Originally Posted by jamie_civic
wont the pump burn up really quick if its always on?
also am i safe with the fmu and stock injectors?...im only boosting 5 psi
You are in Canada........you let your car warm up for the winter don't you ??? If you let your car sit there and idle for that long for warming up everyday.......your pump won't last very long.
As far as the fmu and stock injectors.........i am all stock and i have been running 8-10psi daily for 20 months and more than 20,000 miles with no problems at all.
well im not driving my car much in the winter, but its parked outside and i will have to move it...maybe i should just instal it with the relay like normal and just put a toggle switch on the 12v+ and keep it off for the days i only move the car.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
carquest, civic, directions, fmu, hobbs, honda, hook, injectors, install, installing, instruction, manual, pressure, stock, switch
