Downpipe flange
Old Nov 9, 2005
vicride345's Avatar
vicride345 is an unknown quantity at this point
Downpipe flange
Does anybody know of a place to get a 5 bolt 3" downpipe flange that bolts to the turbo? I've been searching for the past hour and haven't really found any good websites yet. If anybody can help I would appreciate it. Thanx
Cody
Old Nov 9, 2005
dezod's Avatar
7thgen Power Maker
Cody
I do not think you will find a 3" 5 bolt exhaust discharge flange. I think most of them are 2.25" and you can weld a 2.5" or 3" pipe to it. We carry them BTW.
What suze turbo? T25/28 or T3?
Old Nov 9, 2005
vicride345's Avatar
T3 turbo
Old Nov 10, 2005
turboengnr's Avatar
DONT PANIC
ATPturbo.com has some various sized weld-on adaptors. I almost bought the 3" - 4" adaptor for my downpipe, until i changed what i wanted (yet again).
But you may want to get something like this....
**EDIT**
just found this.....
http://www.atpturbo.com/Merchant2/me...egory_Code=FLS
its a 3" 5 bolt T3 wastegate elimination flange.
Old Nov 10, 2005
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
**EDIT**
id check ur turbo before you buy a flange though. not all t3 5-bolt flanges are the same. the bolt spacing can be different as i found out the hard way. measure the gap between the bolts and then compare it to what you see online. a popular flage for the t3 if the one you buy from dezod or atpturbo.com doesnt fit would be the "mercedes style" t3 5-bolt flange. i would look at that if i were you and compare it to the other ones out there to see the difference.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
S1N7H3T1C
Aug 28, 2015 01:00 PM
PierrePierre
Aug 12, 2015 02:42 PM
7thgensurvivor
Jul 27, 2015 08:23 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
