more boost
Old Oct 14, 2005
zach_04LX's Avatar
zach_04LX is an unknown quantity at this point
more boost
Hi everyone,
I have the TSI kit installed and am currently running 7psi. I fixed my problem with running lean, and everything seems to be good now. What would I need to do to run 10psi? I'm pretty sure that 10psi would be a big jump for me, but I don't want to totally trash my engine. Therefore, I figured I would need to get some additional parts. Can someone give me a list of the parts that I would need to get to safely run 10psi?
Thanks,
Zach
Old Oct 14, 2005
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
I have the tsi kit as well. I ran 10psi daily and 13 at the track for 2 years with no problems. tuning is everything though. I would upgrade the clutch and flywheel if i where you but 10psi on stock internals is not that big of a deal. Also look in to a better head gasket. nippon leakless is what i used and it held up great. Just remember tuning..tuning ..tuning. get it just right and youll have no problems. If you need any advice feel free to pm me anytime.
Old Oct 15, 2005
zach_04LX's Avatar
You were running 10psi on the stock engine? Will that severly lower the life of my car? Also, I didn't think you could make it go over 8 without a boost controller, am I wrong? Finally, I was a big idiot when I bought this car and didn't know how to drive a stick, so I got an auto tranny, will that matter? Thanks.
Old Oct 15, 2005
tfnaaf's Avatar
BLDNPSI Mod
Key to any boosted motor is keeping it in tune. And im boosted and an auto trans
Old Oct 15, 2005
andyman97's Avatar
Turbo Guru
If you want to do it right and do it smart, you need to get something that will pull timing. Easiest fix....emanage with rsx injectors. That'll be a safe bet and you can get rid of the tsi fuel controller with the sub injectors.
Old Oct 15, 2005
zach_04LX's Avatar
Well, I installed a manually boost gauge, and now I'm running 10psi. I hope it is okay. Anyone think it is bad to run that much on the stock engine?
Old Oct 15, 2005
ncirom2003's Avatar
if you dont get the fuel and ignition tuned yes. if you get that stuff tuned, plus new cylinder head bolts no.
Old Oct 16, 2005
iamboo's Avatar
Retired - SoCal FI Mod
i ran 10 psi daily and i must say, it was nice while it lasted... trust me, you will feel your motor dying slowly... just keep it low at 6-8 psi for now, get some fuel and engine work done and you should be able to consistently run 10+ psi daily without any problems...
Old Oct 16, 2005
ncirom2003's Avatar
did you have anything done iamboo? like new arp head studs, gaskets, anything? or just 10psi on fully stock motor?
Old Oct 16, 2005
HyaBoosta's Avatar
I too am running 10psi on stock motor. with 105k miles on the motor
Old Oct 16, 2005
ncirom2003's Avatar
100% stock or lil things to help?
Old Oct 16, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
10 psi on the tsi kit would be alright... the turbo is small enough. You can run it no problem.
Old Oct 23, 2005
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
Forget about the motor. That 10psi will nip at that little auto tranny of yours until one day you step on the gas and it says "huh?". Get your tranny built.
Old Oct 23, 2005
ncirom2003's Avatar
quick question, everyone says that the tranny is only good to about 300 hp and beyond that to get it built, what specifically is being done when you "get it built"
Old Oct 23, 2005
Blahman240's Avatar
Is your boost gauge showing 10 psi? Is your kit internal or external waste gate?
Old Oct 23, 2005
tfnaaf's Avatar
BLDNPSI Mod
To my knowledge there isnt anything that you can do for a standard trans in our cars to "Build it" really. Now an automatic trans is a different story I supose you could have the gears cryo treated?
Old Oct 24, 2005
eye_see_you's Avatar
let the devil out
true in some cases.. I am running 12 psi with my TSI kit on a stock motor and my built TCI auto tranny , I put down 206 hp and 168 ft lb of torque after the work was done. but it needs tuning thats the whole issue of anyone .
Old Oct 24, 2005
ncirom2003's Avatar
so for a manual transimission you either stay below that hp or blow the tranny again and again, i know some people have been putting like 500 hp down, what did they have to do to handle that?
Old Oct 24, 2005
A03's Avatar
A03
A03 is an unknown quantity at this point
I guess a good place to look might be central florida turbo? You see the videos online pretty frequently of cars they built up.. ITR's or RSX-Ss.. supposedly around 500HP. The black ITR shop car was pretty damn fast on video if I remember correctly.. I've also seen them on TV during Nopi Tunervision (speed TV). I believe they sponsor one of the big boosted I4 Hondas... even though it usually gets it's *** kicked, it still proves they know how to make a fast car.
I guess the real question is not if you can 'build up' your trans.. the question should be.. do you have the $$$ to build up your trans. Ofcourse it can be done! Just about anything can be done if you have the money.. isn't that how it always goes? hehe okay, this was a useless answer.
Old Oct 24, 2005
ncirom2003's Avatar
lol well i was hoping on an answer of whats being done or where to buy parts cus i can take my tranny apart and put back together
Old Oct 24, 2005
tfnaaf's Avatar
BLDNPSI Mod
Show me a D17 putting down 500hp...............
Old Oct 25, 2005
ncirom2003's Avatar
oh yeah good point, the guy i thought of had a k20 swap but its not impossible to do on a d17......either way you get my point of my question
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
