catch can
Old Oct 11, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
catch can
Hey whats up guys. I just wanted to know who has a oil catch can setup on their car. I see it on a lot of the cars in the magazines but don't fully understand the purpose of it. I'm running a custom turbo kit on my vic, is it a good thing to do. Any comments are greatly appreciated. Thanks guys.
Old Oct 11, 2005
iamboo's Avatar
Retired - SoCal FI Mod
the oil catch can collects any oil that is blown by into the crank case... you're gonna see a lil bit of oil collect which is normal... if you notice that the catch can is filling up pretty quickly, you might have blown piston rings...
for installation...
crankcase breather ---> catch can ---> turbo inlet intake piping (cold pipe) or tap a fitting back to the block
Old Oct 11, 2005
so I would need to run an intake pipe out of the turbo in order to install this. I don't have an intake pipe out of the turbo because the radiator hose is right there next to the turbo intake.
Old Oct 11, 2005
tfnaaf's Avatar
BLDNPSI Mod
its possible to just run the valve cover to the catch can and then a breather filter on the other side of the catch can. Idealy the turbo intake pipe would run a hose to that side to help evacuate the crankcase. As for my system, im jsut running a breather on the valve cover and have had not even a drip of oil out of the breather!
Old Oct 11, 2005
C2i0v0i1C's Avatar
SuperMODrizd
i got one
Old Oct 11, 2005
iamboo's Avatar
i hope you do unless you're sucking air directly into the turbo without a filter... you should have a pipe connected to the turbo which is connected to a filter....
Old Oct 11, 2005
I'm running mesh on the intake side of the turbo. There is no possible way of putting a intake pipe on my setup, damn radiator hose.
Old Oct 11, 2005
civic01vtec's Avatar
I hope your car isn't a daily driver
Old Oct 11, 2005
In fact I drove my car for 4 months since I got the turbo installed with no problems at all. I don't know why people say you need a intake and a filter, thats a bunch of bull. I agree it would be a little safer. I don't mind anymore because my car is in the garage now since a bought my new truck. Thanks guys.
Old Oct 12, 2005
turboengnr's Avatar
DONT PANIC
you can also run your NA car with just the throttle body as an intake. But without a filter, your car will die before its day.
Believe me, i didnt run a filter on my CRX because i really couldnt get a pipe to it thanks to the position of the turbo. Not only did i kill a turbo, but i also killed a motor.
Old Oct 12, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
no filter = dead motor
Old Oct 13, 2005
iamboo's Avatar
you're sucking in about 3-4 times more air than normal... imagine the amount of dust and impurities in the air as it is... now imagine that dust and dirt going into your motor....
even if you stick the filter directly to turbo inlet, it would work....
Wild Cranker
427
Jan 28, 2016 06:49 PM
Whitexj
Sep 30, 2015 02:04 AM
raymondxcho
Sep 29, 2015 09:00 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
SuperCivic2k1
Jul 1, 2002 08:54 AM
