Where to install a BOV ? pic
Old Sep 28, 2005
mxcivic's Avatar
mxcivic is an unknown quantity at this point
Where is the best place to install the bov ... thanks
Old Sep 28, 2005
manahoonie's Avatar
i would say over where the more left arrow is. if you put it right at the intake (right arrow), you may have problems with clearance with the hood (unless you plan to run topless! )
Old Sep 28, 2005
andyman97's Avatar
Turbo Guru
As close to, if not on the intercooler.
Old Sep 28, 2005
mxcivic's Avatar
so u said leave it where is right now ?
Old Sep 28, 2005
civic01vtec's Avatar
It doesn't really matter......the pipe is pressurized.
Old Sep 28, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I've heard that the most efficient places to put blow off valves are either as close to the throttle plate or as close to the intercooler as possible.
Old Sep 28, 2005
PunkingCivic's Avatar
I need TP for my bunghole
yeah there is good
Old Sep 28, 2005
andyman97's Avatar
Turbo Guru
For a minimal boost setup, it won't really matter. Optimal is as close to the intercooler as possible. Most people making real power mount it on the intercooler.
Old Sep 28, 2005
mxcivic's Avatar
Originally Posted by PunkingCivic
yeah there is good
where!!
Old Sep 29, 2005
turboengnr's Avatar
DONT PANIC
just put it where you have the damn bosch bov at. simplifies everything.
Old Sep 29, 2005
mxcivic's Avatar
its cause that is not my engine bay, i already have it in where the other arrow is... but someone told me that where is the bosch one is better thats why i asked !!!
Old Sep 29, 2005
Alex1's Avatar
Would you please be kind enough to explain why mounting the BOV on or as close to the intercooler as possible would be better in higher boost setups?
Old Sep 29, 2005
Drk01Civic's Avatar
Here is a copy of a post I found in another forum. It's one thought on why as close to the throttle as possible is a good position.
Originally Posted by somejackassonanotherboard
THis is to prevent excess pressure from hitting the throttle plate and keep the air pulsation against it down. the closer your BOV is to teh throttle body the better off you are. It's alost easier to force the air out at the end of the tube rather then in the middle w/ a T in it. Just think of it in velocity, the air is already moving that direction, it is almost at it's run thru the intake(before the throttle plate) and coming out of hte biggest storage chamber in the system. Best spot to vent, the end of the storage tank. It just keeps for a smoother air pattern into the throttle plate.
Old Sep 29, 2005
ritalin's Avatar
ritalin has a little shameless behaviour in the past
I'd mount it closer to the throttle. That way after you blow off and boost is running through your intake charge pipe it won't have far to go before it hits the throttle whereas the further down it is the farther the air has to travel. Then again mounting it closer to the ic means the temp will be cooler as it travels up the pipe towards the throttle.
Old Sep 29, 2005
ragingSPAM's Avatar
I just burnt my tongue
its better mounted further from the throttle...hood clearance and performance wise...the closer it is to the intercooler the better but u want to have it the the left arrow is cuz thats one of my most optimum positions for it
Old Sep 29, 2005
mrDFWmechanic's Avatar
i know its off topic but thats a kickass manifold
Old Sep 29, 2005
ritalin's Avatar
Looks like a full race knockoff. tubular>log
Old Sep 29, 2005
exactly what i was thinkin i bet it flows better and makes more power than the other manifolds
Old Sep 29, 2005
ritalin's Avatar
If its anything like the full race versions i've seen it makes tons more power than a good ss log.
Old Sep 30, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
it is true, closer to the throttle body is the best...but obviously as close as you can get it w/o messing with your hood clearance...
cause when the tb plate closes, it can vent right away, and its the furthest from the turbo, which reduces chance of compressor surge
mistermenphis22
Apr 3, 2016 08:06 AM
S.Klinck
Feb 10, 2016 02:19 PM
robbie374
Jul 7, 2015 02:56 AM
chgofirefighter
Apr 18, 2015 08:08 PM
ImmortalEX
Nov 8, 2001 09:52 PM
