Help With Pump Used For Water Cooled Turbo Setup..
Old Sep 22, 2005
black01civic's Avatar
From: Mukwonago, Wisconsin....around the Milwaukee area
black01civic is an unknown quantity at this point
Ok so i have a turbo setup on my 01 civic....however the setup has a water cooled intercooler......i know that sucks , however the pump the kit is currently using is a non-submersible pump used for small ponds or to drain things...and is extremely loud....wondering if anyone can tell me if there is a quieter pump i can use that has 3/4" inlet and outlet....thanks any imput will be greatly appreciated.
Old Sep 22, 2005
Exclamation
one more thing if you could tell me anything you know about warner-ishi ihi turbo's would also be appreciated.........is it worth even thinking about rebuilding this turbo(cost from what i've researched around $300-$350) or buy a new garrett t3 turbo($450)?
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
an ihi turbo is a very efficient turbo when compared to others its size.
The ihi turbos usually have a slightly different flange than a T3 or T25. So you probably wont be able to simply swap turbos.
And air-water intercoolers are very good for drag racing and short road races. They are decent for daily driving (as long as you have a large heat exchanger for it). If you have a large reservoir, you can add ice for a very nice cooling effect that helps tremendously with power gains.
As for a pump, you can get a 12v bilge pump for a boat. If you get the right one, they flow a hell of a lot of water, and they last quite a while.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
Supramk3
Jun 11, 2015 11:13 AM
Lopes101
Jun 7, 2015 08:04 PM
brian257
Jun 4, 2015 08:17 PM
