For those who dont know what sleeves are.....
Old Sep 16, 2005
turboengnr's Avatar
DONT PANIC
Here are some pictures of what they look like out of the car.
I was visited by the UPS man about an hour ago. And he brought me these.
Old Sep 16, 2005
robbclark1's Avatar
Retired suspension supermod.
They are big rings that go in your cylinders to keep you from cracking the block. They are reinforced for better handling of pressure and heat. They are better than a block guard and definitely better than studding your cylinder walls.
I know you aren't going to use those, so send them my way...
Old Sep 16, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
so would you recommend getting these if you plan on boosting, especially over around 8 psi?
Old Sep 16, 2005
Michalo187's Avatar
Abortion Survivor
I think they are for really high boost applications like i know his goal is 400whp. How do they look installed??
edit: but then again all cars are different and some can crack even at 8psi i guess its how lucky you are. but to go over 10 you definetely need rods and pistons
Old Sep 16, 2005
PoorCollegeBoy's Avatar
Stolen digital camera = no ninja picture for me
PoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the rough
I was expecting pictures of your arms tattooed from the shoulders to the wrists
Old Sep 16, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Cool:
Is good to know that they made a direct replacement.
I had to use the D16 sleeves.
I updated my engine build thread with this new info.
Sleeves are a good insurance for your block whether high boosting or not.
If one of your rods or pistons go, it will prevented it from going thru your block.
Also they disperse heat more efficienly.
Sleeving your block will not stop them from walking (moving side to side under high pressure)
A block guard is a good idea.
Just remember to bore out the holes bigger see picture below:
Old Sep 16, 2005
Michalo187's Avatar
Abortion Survivor
how much where those sleeves?
Old Sep 16, 2005
DelSolid's Avatar
DelSolid is an unknown quantity at this point
Originally Posted by Supermex
Sleeving your block will not stop them from walking (moving side to side under high pressure) A block guard is a good idea.
That depends on the type of sleeve. A closed deck or spoke design will not walk. Look at these photos: http://www.7thgencivic.com/forums/sh...=153591&page=3
to see an alternate sleeve design that cant walk side to side.
Also, I can push a rod out the side of any motor, sleeved or not!
Old Sep 16, 2005
turboengnr's Avatar
DONT PANIC
Supermex,
I have a block guard also, and i will be taking your advice and making the coolant passages larger.
I have spent countless hours on the phone with JE, Arias, Crower, and Darton talking to them about what i wanted to do. My goal is 15 psi daily, and 25+ psi at the track. I wish to make 425-500 whp. And with the parts i purchased, it will not be a problem. My buildup is good for more than 600 fwhp, according to the manufacturers.
The only thing holding me back from making these numbers is my engine management. I cannot afford an AEM, so i am currently limited to an emanage. But that will be enough to run my 15 psi daily.
Darton makes the D17 sleeves by taking the D16 sleeves, and shortening them. And these are flanged sleeves, so it is next to impossible to drop (sink) a sleeve.
The sleeves retail for about $235. Then you have to pay someone to install them.
Old Sep 16, 2005
andyman97's Avatar
Turbo Guru
Sweet man, good luck in making your goal.
Old Sep 16, 2005
blouisgod's Avatar
Life Begins > 6800rpms
Nice parts - I cant wait to see that dyno and video!
Old Sep 16, 2005
turboengnr's Avatar
DONT PANIC
It still wont be for a while. The rods are still 5-6 weeks away. And the pistons are still 2-3 weeks away.
Old Sep 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
So that is a "off the shelf part" from darton now? Or did they mof them per your order?
Old Sep 16, 2005
turboengnr's Avatar
DONT PANIC
they make them to order. But that is the accurate part number, so if you call them with it, they will make you the same thing i purchased.
They have the D16 sleeves in stock, so it takes them about a week to cut it down and ship it out.
Old Sep 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
Cool, thanks for the info, keep us updated on your progress
Old Sep 16, 2005
turboengnr's Avatar
DONT PANIC
yup!
Old Sep 17, 2005
Michalo187's Avatar
Abortion Survivor
What about your tranny? What are you going to do when it blows up at 300whp? Do you have axles?
Old Sep 17, 2005
turboengnr's Avatar
DONT PANIC
Right now, I have 2 trannys, 2 sets of axels, 2 extra cylinder heads, 2 extra cams, an extra set of rods, extra crank, extra stock block (complete long block), extra sub-frame, extra ECU, extra wiring harness, intake manifold, throttle body, all the sensors.
i have already been through 2 trannies with the stock motor under boost.
I have been through 4 clutches, 2 flywheels, 6 sets of tires, 2 sets of slicks, 1 set of DR's, and now 1 motor.
When it brakes, i will replace it. Then i will drive easily til i have a replacement for that.
Old Sep 17, 2005
C2i0v0i1C's Avatar
SuperMODrizd
235 bucks and there is a freaking part number i do seeeeeee......hmmmmmmmmmmmmmmmmmm
Old Sep 17, 2005
vietstylez's Avatar
BALLER
Old Sep 17, 2005
mrDFWmechanic's Avatar
wow thats gonna be a sick D17 engine when ur done, what turbo are you gonna be running with that crazy setup ?
Old Sep 17, 2005
turboengnr's Avatar
DONT PANIC
look at my avatar.....
its a turbonetics 60-1
Its been sittin in my garage for about 2 months. I will build the rest of my turbo setup as soon as my shoulder heals.
Old Sep 18, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Hey good job. Waiting sucks. After your build-up, let's buy you an HKS F-CON V PRO and have your car towed to an HKS pro dealer for tuning. Wiring will be a bitch but we can do it. Hopefully, I'll be running one with my next car.
Old Sep 18, 2005
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
Supermex,
nice goals you have there!
Old Sep 18, 2005
turboengnr's Avatar
DONT PANIC
Sounds good garret! Once i get some money, we will be set. Wiring isnt much of anything. Its pretty simple.
Old Sep 18, 2005
supermex's Avatar
Supermex,
INSTALLATION is the key!
They is going to be so much pressure pushing the sleeves into the block that the crank shaft drive will need to be honed and the block check for warpage.
After the sleeving is done I will recomend decking the top and the sides of the block were the intake manifold and the exhaust manifold meet.
make sure all is straight and flat.
Old Sep 18, 2005
MYK1013's Avatar
so, is that a short or long sleeve??
just playin' thanks for the new 411 though.
Old Sep 18, 2005
puidokas's Avatar
puidokas is an unknown quantity at this point
Do the sleeves replace stock sleeves, or does the block have to be machined.
Old Sep 18, 2005
allmotor's Avatar
nor cal 7thgens
200 for the all of the sleeves?
Old Sep 18, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
You're gonna make it in a mag!
How long you think that tranny will last at 25psi?
