cel light with turbo kit
Old Sep 15, 2005
  #31
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by Daemones6
I have the same problem with the CEL being on. Because I have no CAT, a friend of mine said that it was the exhaust O2 temp sensor. I am wondering if I can hook an O2 Simulator to the sensor to correct. Any thoughts?
Cheapest way is mechanical o2 sim. Cheeck my signature for soem pictures, it uses 2 - 18mm sparkplug non-foulers
Old Sep 16, 2005
  #32
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
Wow! How did you do that? That looks perfect. and it worked?! Hey, if it's not too much trouble, PM me with the instructions on how to do that to a plug and I'll get right on it to see if it works for me!
Old Sep 16, 2005
  #33
tfnaaf's Avatar
BLDNPSI Mod
Here is a LINK to the first one i foud a DIY of it...
And BTW im going on 3000 miles and still no check engine light for NO cat!!!!
Old Sep 17, 2005
  #34
Sharonda's Avatar
Sharonda is an unknown quantity at this point
a misfire caused a blown head gasket?
Old Sep 18, 2005
  #35
Daemones6's Avatar
Link didn't work. :-(
Old Sep 18, 2005
  #36
tfnaaf's Avatar
BLDNPSI Mod
it works, you just have to be a member of ephatch
Old Sep 18, 2005
  #37
tfnaaf's Avatar
BLDNPSI Mod
You now need to drill out 1 of the non foulers using a 1/2" drill bit. When finished this is what it will look like.
o2 Sensor inserted in the modified non fouler
Second, unmodified non fouler now installed on modified non fouler
Old Sep 20, 2005
  #38
drunkenmagnum's Avatar
does napa carry those?
Old Sep 20, 2005
  #39
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I was looking to these fouler here in local autoshops and they dont have it.
Can someone buy me 2 of these and sent to Toronto, Ontario????
I'm no joking guys!
Old Sep 20, 2005
  #40
ncirom2003's Avatar
^ so are you just holding the 02 sensor further out so it picks up less emissions or something?
Old Sep 20, 2005
  #41
tfnaaf's Avatar
BLDNPSI Mod
What it does is lessens the amount of ehaust that gets to the second O2 sensor. The sensor then sends a signal to the ECM that is a different signal of a higher AFR fooling the ECM in to thinking there is a cat there doing its job.
Old Sep 20, 2005
  #42
tfnaaf's Avatar
BLDNPSI Mod
most of your parts stores do carry these, like shucks, checker, kragen. I imagine pepboys, autozone and many others do also. I would think that napa would have them , jsut call and ask for 18mm spark plug non-foulers.
Old Sep 20, 2005
  #43
Our parts stores do carry "HELP!" products, but I havent seen non-foulers.
But, good poiter with napa, we have those here.
Supramk3
May 11, 2015 07:55 PM
mikevtec
May 3, 2015 01:36 PM
cloudguy
Apr 28, 2015 05:02 AM
Fastfebur
Apr 26, 2015 11:57 PM
Boosted
Nov 21, 2003 11:03 PM
