Hasport PRess Release K24 Mounts for 2001+ Civics
K20 Member
Touch it... He won't bite, He'll just come at you pretty quick.
where can you get the engine from? I mean online. Also, what are some codes? I know the k24 is in the crv as well as the tsx I wouldn't want the weaker of the two.
k24a1 = crv 166hp
k24a2 = tsx 200hp
k20a = dc5 220hp
k20a2 = rsx-s 200hp
k20a3 = si/rsx 160hp
Anybody know where I can get the ESK24???
My car is going in the shop on the 12th. Help me out. I couldn't find it at Hasport.com site.
I just burnt my tongue
Originally Posted by stl01civic
www.car-parts.com
k24a1 = crv 166hp
k24a2 = tsx 200hp
k20a = dc5 220hp
k20a2 = rsx-s 200hp
k24a1 = crv 166hp
k24a2 = tsx 200hp
k20a = dc5 220hp
k20a2 = rsx-s 200hp
and its most likley a K20Z2 which is prolly in the 2006 Civic Si at 197hp
Originally Posted by ragingSPAM
u forgot about the new K20Z1 which is in the RSX/Integra Type -S...210 hp
it is not out yet. sooo i don't bother to list them.
I wish I was asian
www.car-parts.com
k24a1 = crv 166hp
k24a2 = tsx 200hp
k20a = dc5 220hp
k20a2 = rsx-s 200hp
k24a1 = crv 166hp
k24a2 = tsx 200hp
k20a = dc5 220hp
k20a2 = rsx-s 200hp
www.car-parts.com
k24a1 = crv 166hp
k24a2 = tsx 200hp
k20a = dc5 220hp
k20a2 = rsx-s 200hp
k24a1 = crv 166hp
k24a2 = tsx 200hp
k20a = dc5 220hp
k20a2 = rsx-s 200hp
• HP 220 @ 8000 rpm
• Torque 152 lb/ft @ 7000 rpm
• Redline 8400 RPMS
• Bore 86mm
• Stroke 86mm
• Comp Ratio 11.5:1
• Displacement 1998cc
• Specific output 110HP/L
Trans Specs
• 1st 3.27:1
• 2nd 2.13:1
• 3rd 1.57:1
• 4th 1.21:1
• 5th .97:1
• 6th .78:1
• Final Drive 4.765
K20A - EURO spec
• 147 kW (200 hp) @7400 rpm
• Torque 196 Nm @5900 rpm
• Redline 8100 RPMS
• Bore 87mm
• Stroke 86mm
• Comp Ratio 11,0:1
• Displacement 1998 cm3
• Specific output 100HP/L
K20A2 – US spec RSX type S motor
• 200 HP@7400 rpm
• Torque 142 lb/ft @ 6000 rpm
• Redline 8100 RPMS
• Bore 86mm
• Stroke 86mm
• Comp Ratio 11.0:1
Trans Specs
• 1st 3.267
• 2nd 2.13
• 3rd 1.54
• 4th 1.14
• 5th .92
• 6th .73
• Final Drive 4.388
K20A3 – US spec Ep3 / RSX motor
• 160 HP@6500 rpm
• Torque 132 lb/ft @ 5000 rpm
• Redline 6800 RPMS
• Bore 86mm
• Stroke 86mm
• Comp Ratio 9.8:1
• Specific output 80HP/L
Trans Specs
• 1st 3.662
• 2nd 1.769
• 3rd 1.212
• 4th 1.14
• 5th .92
• Final Drive 4.765
K24A2 – US spec TSX motor
• 200 HP@6800 rpm
• Torque 166 lb/ft @ 4500 rpm
• Redline 7100 RPMS
• Bore 87mm
• Stroke 99mm
• Comp Ratio 10.5:1
• Displacement 2354cc
• Specific output 88.33Hp/L
Trans Specs manual
• 1st 3.262
• 2nd 1.88
• 3rd 1.35
• 4th 1.0
• 5th .82
• 6th .659
• Final Drive 4.765
K24A – US spec CRV motor
• 160 HP@6000 rpm
• Torque 162 lb/ft @ 3600 rpm
• Redline 6500 RPMS
• Bore 87mm
• Stroke 99mm
• Comp Ratio 9.6:1
Trans Specs manual
• 1st 3.262
• 2nd 1.88
• 3rd 1.35
• 4th 1.0
• 5th .82
• Final Drive 4.765
Originally Posted by HondaLuver
lol, fair enough... life goes on... come one people lets get these swaps going...~!
actually i have more specs..
click here for the direct article
http://www.xproductionz.com/k20swap/k20swap.html
or click here for the thread
http://www.7thgencivic.com/forums/sh...d.php?t=227132
Originally Posted by kornsined
^^^^hey did you need the starter from an rsx? it wasn't listed in your article parts list.
