to all those boosted, with or without internals.
Old Sep 8, 2005
  #31
dezod's Avatar
7thgen Power Maker
Originally Posted by ncirom2003
my whole thing is, im tight on cash so i dont want to pay to tune the car now then pay again when i get stage 2 cam and pay again when i get internals and stuff and turn boost to 15psi.
Pay and pay again. Get used to it with a forced induction car. IT WILL NICKLE AND DIME YOU TO DEATH.
You have to pay to play. Sorry bro. The only good thing is, if you purchase our kit, we include a mildly tuned map to get you started for 8 PSI. That saves some time & $$. This map was made over probably 15-20 hours of street driving.
Old Sep 8, 2005
  #32
ncirom2003's Avatar
well i already bought the kit. do you guys sell this map? also do you have maps for other psi settings and how much?
Old Sep 8, 2005
  #33
civic01vtec's Avatar
I have been running 8-10 psi daily 18 months now with the SF fuel system that so many ppl care to hate. I have hit 13 psi once and that **** was fast as hell.
I have a EX and a completely stock motor. If my motor goes.....i got a complete spare with 11,000 miles sitting in my garage waiting to be dropped in. When my motor goes......so does the modding. Back to stock for me.....no more wasting money on these SOHC's.
Old Sep 8, 2005
  #34
ncirom2003's Avatar
does it just randomly hit 13 psi cus you dont hav a controller or did you turn it to that?
and did you ever get it tuned?
edit: also, do you beat the thing? cus i sometimes feel the need to just floor it till 7grand then maybe again in the next gear.
Old Sep 8, 2005
  #35
C2i0v0i1C's Avatar
SuperMODrizd
20 months for what, u have all the part numbers there, its not going to take two years to make, i did a special custom order for the very first ones and it only took 6 months
Old Sep 9, 2005
  #36
I have a hallman pro mbc......i was adjusting it and i turned it up too high.
No, i didn't get it tuned.....i had a emanage and type s injectors but i sold them b/c i needed money. I am just running the sf fuel system.
I beat my car sometimes.......but not too often. My car has 60,000 miles on it.......15,000 of them boosted and i am still on stock clutch
Old Sep 18, 2005
  #37
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
was running my car at 13psi daily and it ran fine. But I did spend a lot of time tuning it for perfection. Now I just run 6psi cause I burned my rings and am loosing comp. in one cyl. Was my fault though. Didnt adjust for the differnt fuel form Germany to Cali. Doh. Its all good though. Building my 2nd motor now with all crower parts. Built for High boost. Cant wait to drop this baby in.
Old Sep 18, 2005
  #38
andyman97's Avatar
Turbo Guru
Originally Posted by 2K1Civic17"Gabe
bottom end is much more expensive than the head. My Subaru will be built for stage 2 though.
10psi on a DX/LX is the most I would boost, and 8 on a EX. Thats pushing it, but can be done with a very good tune. EX has higher compression, so I wouldnt boost as high on that head.
Valvetrain is not cheap to upgrade, it gets quite expensive.
Do you understand that the head on the EX has absolutely NOTHING to do with the compression ratio? A c/r difference of .4 is not going to mean you can run 2 more psi of boost.
Think in terms of cyliinder pressure, not boost. It doesn't matter how much boost you run but how much air your turbo flows. One turbo may make 220 hp at 10 psi, whereas another may only make 180 hp.
The tune has alot to do with making things run properly, but at the same time, I think trying to make over 250 hp on a stock motor is as far as I would go. You can gain ~20-30 hp alone from tuning if you have a tuner that knows what he's doing.
And if you plan to build your motor, alot of the parts you probably got (depending on which kit) will not make the power your engine will be able to support.
Old Sep 18, 2005
  #39
ncirom2003's Avatar
^ cylinder head has something to do with CR, why do you think that people mill there heads? to squeeze a lil higher CR into the motor. (and for a sure flat surface) but if the ex head has a smaller volume than the lx than it will make higher CR on the lx.
Old Sep 19, 2005
  #40
andyman97's Avatar
Turbo Guru
The head does have something to do with cr but in the instance of the d17 motors, it's based on the rotating assembly, not the head, at least as far as the differences in compression go for the d17. It's not based on the head or the head's volume. They are both 1.7 engines. Combustion takes place in the combustion chamber, where the head meets the block, not inside the head. I know why people mill their heads, I've had heads milled before but as far as I'm concerned, sizing the piston to make your goals is smarter than trying to mill a head to get a higher cr.
Old Sep 19, 2005
  #41
Nick's Avatar
Formerly 2blu
anybody ever thought of running a high comp. boost motor??? If u are going to build your motor for boost, why not put high comp. pistons in? Shure you will have to run less psi over all, and tuning will be harder, but in the end I think it would pay off with increased responce and broader power curve.
Old Sep 19, 2005
  #42
ncirom2003's Avatar
i agree that its definately better to just get pistons than to mill down the head,
i thought you were saying that a head never matters for CR, not specifically for the d17
Old Jan 4, 2006
  #43
Eclectic's Avatar
Eclectic is an unknown quantity at this point
what does driving a boosted car feel like? is it loud and more pull and increased acceleration?
Old Jan 4, 2006
  #44
tfnaaf's Avatar
BLDNPSI Mod
Fun and yes
Old Jan 4, 2006
  #45
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Old Jan 4, 2006
  #46
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
think about it this way: You're driving your civic, foot to the floor, whining out your motor, you hear another little whine start and it feels like someone has started pulling your car faster and then you start to grin from ear to ear.
Old Jan 4, 2006
  #47
Michalo187's Avatar
Abortion Survivor
It feels like your on a runway taking off in an airplane not to fast at the start but then super fast. HAHAHAHA It also sounds like you have a huge intake sucking in all the air it can and the blow off valve sounds super sexy like if all your air in your tire just went out.
Old Jan 4, 2006
  #48
Eclectic's Avatar
so it's loud?
was wondering if there's someway to make it quieter so it can work on a sleeper setup
one more thing, i've been reading around and i've read that you gotta maintain your engine more or else the turbo will eventually wear it down....what specifically will happen to the engine? any parts to upgrade or add to prevent this?
Old Jan 4, 2006
  #49
PrecisnTec's Avatar
so it's loud?
alot of your questions are in the faq's. it's really not all that loud. as far as maintenance, you gotta' change oil more frequently. (2000 - 2500 miles), according to Corky Bell's book, it will take 10,000 miles off a 100,000 mile motor.
Old Jan 4, 2006
  #50
ncirom2003's Avatar
driving a boosted car is fun but having a non boosted car with the same hp is better because with a turbo, lets say on our car you have a 100hp engine and the turbo gives it 200. so your driving around and until the turbo kicks in youve only got 100 hp so youve got a delay, if it was naturally aspirated and made 200hp without a turbo youd always have that extra hp no matter what speed or anything.
its more detailed but this will get the point across.
although i havent driven a turbo civic yet, i drove an a4,supra,s4.
oh and yea extra maintenance. as for life of the engine, if you get a crappy tune itll destroy the engine cus it wont run good but you can have the opposite too.
Old Jan 4, 2006
  #51
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
hmm.. i think i may have to disagree with you on that.. a n/a car with 200 hp car doesnt make 200 hp throughout the entire rpm range. same goes for a turbo civic, it doesnt make peak ammount of hp until a certain point in the powerband.
if you have a n/a car rated at 200 hp and a turbo car rated at 200 hp the turbo car will win.
Old Jan 4, 2006
  #52
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Yeah in some situations a narrow power band will make a n/a car less streetable than a turboed car. Some people even argue that the s2000 needs to be reved too high for daily driving. The generalization that any old n/a car with 200hp will loose to any turbo car with 200 hp is also false.
Basically all power has its draw backs. Engines that are powerful through a wide powerband use a lot of gas and take a lot of abuse, but are of course extremly fast. It really is about balance as well as setting up a goal then accomplishing that goal.
Oh yeah it is also about being smart and doing things the right way. When I say the right way well you have to talk to people with experiance and try to learn as much as possible to find the "right" way.
Old Jan 4, 2006
  #53
ncirom2003's Avatar
yea i know, but i didnt feel like explaining all that to him as long as he gets the idea of turbo lag.
i disagree. and there are many things to take into consideration also.
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
