Question about swaps
Old Aug 24, 2005
Michalo187's Avatar
Abortion Survivor
Ok well i am more into the forced induction but my friend came up to me and asked me to help him pick out the best engine swap idea for his 1997 Civic Hx. He was asking me what engine is the best for this civic. Could you guys help me out i was thinking b16 or k20a3. Also How much would a shop charge to install (rough estimate)and where should i look into buying a engine besides this forum. Thanks for your help
Old Aug 24, 2005
allmotor's Avatar
nor cal 7thgens
deff b16 1st gen. People can say swap a k20a2, or gsr this and that but when u start buying the parts like shift linkage, mounts, axles etc it all adds up money wise and for now it would be good for him to start on a b16 with bolt-ons. Then when he saves for money he can do internals or maybe a b20 bottom swap and go all out. I have been looking around and the b16 swap for me if i do it is gonna be around low 2,000's. And tell ur friend bigger isnt always better. My friend with a b16 swap in a eg with only aem cai, dc header (bad), 2 1/2 inch exhuast stock internals and timming ran a 14.1. And his friend has a gsr swap and with alot more mods he ran a high 14. Main reason is he has better tires and suspension so u should invest in that as well. Here's a site hmotorsonline.com but look around and u can deff find a better deal. And tell ur friend to go on honda-tech to find out more info.
Old Aug 24, 2005
Michalo187's Avatar
Abortion Survivor
Thanks for the help we were quoted 4000 for a everything plus installation i don't know if thats a good deal. I really don't know anything about swaps
Old Aug 24, 2005
allmotor's Avatar
nor cal 7thgens
dam 4000 for a b16 thats kind of expensive. Do they do good work? Tell him to find someone on honda-tech/locally that can do the swap or help for alot less.
Old Aug 25, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
if you diy install its much cheaper
my buddy got a quote on a b16a1, $3000 CDN for everything including axels, tranny, motor, mounts etc.. into a 96 coupe
i'd say
b16= good high end power, no torque
b18b= decent torque, good for boost (lower compression) but no vtec
b18c(1)= great engines, pull hard
b18c5= expensive, but upgraded internals, higher compression
b20= unless your doing a frankinstine, stay away from b20's
oh and you still need shift linkage and mounts no matter what b series motor you buy
Old Aug 25, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
iirc, 1st gen b16's are obd1 ... not very legal.
I'd say get a b16a2 from a 99 si ...
k20a3 would cost too much and would not be worth it at all
Old Aug 25, 2005
ajhdragon's Avatar
7thgens official a$$hole
b18c for a good all motor car or great for boost. b20 if you wnt a bad a$$ all motor car. my neighbor's b20 integra is pretty damn nice without the vtec head. but in all even if you do a complete type r b18c5 swap with tranny and everything it should, cost about $4.5-5k for everything includeing install.
Old Aug 25, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
usdm b20's are 126 hp iirc ... that doesn't sound nice to me ...
Old Aug 25, 2005
exturbo6's Avatar
do a Ls vtec swap or a all motor GSR or GSR turbo. dont do a b16
Old Aug 25, 2005
dezod's Avatar
7thgen Power Maker
B18 boosted
Old Aug 25, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
I say B16 as well.... enough aftermarket support to keep up with a B18
Old Aug 25, 2005
dezod's Avatar
7thgen Power Maker
True for the most part.
B series in general....18 or 16 is a greatly supported motor.
Old Aug 25, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
D17!!!
Old Aug 25, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
boosted ls/vtec. If you look around honda-tech. you can get a lot of cheap parts from it. but beware of scame.
Old Aug 25, 2005
ajhdragon's Avatar
who said it was USDM? plus that is also the numbers from the Honda CRV which dosn't have the tunning for the HP numbers. and once you but on the b18c intake manifold, header, full exhaust, and tune the ecu, its runs pretty damn good.
Old Aug 25, 2005
mxcivic's Avatar
mxcivic is an unknown quantity at this point
Originally Posted by dezod
B18 boosted
yep i think the samee !!!
Old Aug 25, 2005
allmotor's Avatar
nor cal 7thgens
b20 is for torque and most people slap on a gsr or b16 head for more power anyways.
Old Aug 25, 2005
Theeyo's Avatar
Theeyo is an unknown quantity at this point
cheapest route...go LS(b18b/a) Boost
dbagaus
SOHC D17Ax non-VTEC - VTEC Engine Swaps
70
Feb 22, 2023 04:26 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
codys civic
May 31, 2015 03:28 AM
ClutchMasterOG
May 31, 2015 03:25 AM
viper775
Dec 9, 2001 10:52 PM
