turbo exhaust
Old Aug 23, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
turbo exhaust
now before you all start freaking, i did just search for this issue and found little help
who here is running a 3" exhaust on turbo?
my exhaust shop was showing me thier raw 3" piping and the damn thing was HUGE
im running a t3 w/ stock internals, what would you recommend 2.5 or 3" from downpipe through?
Old Aug 23, 2005
eye_see_you's Avatar
let the devil out
3" is a hell of alot of piping.. but I have the TSI extreme kit with no cat and the greddy evo2 exhaust now and I can tell you it does make a difference due to pipe size for instance the tone of the exhaust got deeper and the turbo spools even faster now
Old Aug 23, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
U need a Turbinator........ $79. ;-) j/k. I would do 2.5" piping unless u gotta setup like ^
Old Aug 23, 2005
dezod's Avatar
7thgen Power Maker
2.5" is fine for up to 500whp
Old Aug 23, 2005
Alex1's Avatar
But don't you get quicker spool time and make a bit more power with 3" piping?
Old Aug 23, 2005
civic01vtec's Avatar
blah.....i am still running stock exhaust
money > me
Old Aug 23, 2005
dezod's Avatar
7thgen Power Maker
Depending upon boost levels, turbo, downpipe, vehicle design & restriction w/ kit....too many variables to make that general of an assumption.
The power difference if any will be 5-15whp. IF THAT at same boost levels and all. You will loose TQ as a result. The 3" will just merely reallocate the power to the upper RPMS where exhaust gases pulses are greater. You will sacrifice low end and mid range as a result.
Old Aug 23, 2005
turboengnr's Avatar
DONT PANIC
"the best turbo exhaust is no exhaust" --Corky Bell
That means that the bigger, the better.
If you are running a stock motor, 2.5" will be more than enough. Going with a 3" will not yield you a large gain. It will just be more expensive and louder.
I went 13.6 @ 102 on 2.5" exhaust and a 2.5" downpipe. I ran the same time with a 3" downpipe and no exhaust. Both stock motors.
Old Aug 23, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
So if you planning on building up the engine for more boost, you might as well get 3 inch piping?
Old Aug 23, 2005
turboengnr's Avatar
DONT PANIC
if it will benefit you, yes.
We found that on an SRT4, we gained more than 40 whp when we swapped from a 3" to a 4" exhaust.
The SRT was not stock. It made 550 whp on the turbo alone, and had a 100 shot of nitrous on top of it. Had a different comp. ratio than stock (higher, but wont go into details), and it ran a lot of boost (again, wont go into it)
Basically what im saying is:
if you have a need for it, then get it. If you will eventually have a need for it, then get it, it wont hurt you.
Old Aug 23, 2005
dezod's Avatar
7thgen Power Maker
Since we are quoting QB.......That is correct. To an extent.
However, Corky did have an entire chapter on exhaust systems in his infamous bible. On the 2nd or 3rd page of the chapter, he has a very nice graph with a correlation of how much of a diameter exhaust you should have with respect to engine power. 3" will work majic up to and more than 700hp.
Found it..........Chapter 11, page 133 has the graph
On the preceeding page, 132, I quote:
Originally Posted by Corky Bell
It is easy to get overeager on fitting large-diameter pipes into an exhaust system. "The larger the better" is not the case. As indicated in Chapter 5, there is an exhaust gas velocity that ought not to be exceeded. I am going to suggest that for exhaust calculations, this is approximately 250ft/sec...
Old Aug 23, 2005
cwick187's Avatar
cwick187 is an unknown quantity at this point
Ok, so you can use pretty much any 2.5" aftermarket exhaust and it shouldn't affect Hp and Tq on a basic setup??? I'm getting a turbo kit soon, but I want to use an exhaust that is still not very loud and noticable..I know the more "quite" exhaust systme my restrict flow, but would it really make that much of a difference?
Old Aug 23, 2005
thanks for the opinions
i think im gonna do a 2.5 downpipe back w/ high flow cat
hopfully be put in next week with the turbo, but im still awaiting my oil lines in the mail
i'll take some pics
Old Aug 23, 2005
turboengnr's Avatar
DONT PANIC
im simply stating the gains that we achieved with the mods we used.
I quoted him out of simplicity. For the most part, its true. I ran a completely open 3" downpipe that was ~12" long. Then i ran my full 2.5" exhaust. I had a negligable gain on the dyno. But its a gain, none the less.
I did the calculations. But when tested the open downpipe was the best (for my car). Everyone elses cars may be different. No 2 cars are the same. Thats why some (completely bone stock) SRT4's make 215 whp, and others make 235 whp on the same boost. Thats why some Hondas make 90 whp, and others make 100. Yet they all have the same parts.
Old Aug 24, 2005
Alex1's Avatar
I understand a whole lot better now thanks to you guys.
Old Aug 24, 2005
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
I have the same exhaust as you and Im also installing the TSI extreme kit. I was curious to know how the exhaust sounds after turbo??
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
