Need Help ASAP! Emanage fried somthing??
Old Aug 17, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
Hey guys
so i finally recieved my support tool today, went and plugged the emanage into the ecu (with my emanage harness) and the car would not start.
i can hear the fuel pump prime
engine will turn over, but not startup
i unplugged my emanage and tried starting up with my regular ecu, and it STILL wont start
so i checked my plugs and they seem'd fine
unplugged the battery for 15 min to let the ecu reset, and still the same problem
Could it be possiable that the emanage fried my coils or ecu? what are the sympotoms of both?
thanks
Old Aug 17, 2005
C2i0v0i1C's Avatar
SuperMODrizd
has it worked ever? like has it ever started
Old Aug 17, 2005
no this was the first boot with it
Old Aug 17, 2005
C2i0v0i1C's Avatar
SuperMODrizd
engine swap? with old ECU
Old Aug 17, 2005
no no
i just simply plugged in my emanage and tried starting my car and thats where the problem started
the car was running perfectly before i plugged it in
Old Aug 17, 2005
Havok2k1's Avatar
Wicked Pissah Admin
gotta be a wiring issue
Old Aug 17, 2005
tfnaaf's Avatar
BLDNPSI Mod
yup, yup tripple check your wiring!
Old Aug 17, 2005
found the problem
i checked over all my fuse's and my ignitor coil fuse was the problem
Old Aug 17, 2005
exturbo6's Avatar
maybe you blew a fuse?
Old Aug 18, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
Just alittle word of adivse, dont know if you did this or not, make sure you UNplug your battery when your are working around your ecu or emanage. I have seen to many fried ecm's because of people soldiering, or improper install while having the battery connected. You got lucky just a fuse blew =)
Old Aug 18, 2005
thanks for the heads up
i though i would be fine because it was a simple p&p harness, but i wont do that again without a battery disconnect
