1/2 Radiator for 7thgen
Old Aug 17, 2005
hustlelikem0fo's Avatar
Is the only thing holding up using say a 1/2 Fluidyne radiator from an EG hatch in the 7thgen, the mounting points for the radiator? Say, I wanted to put one in my car, is that all i would have to worry about and if i figured out how to mount it, would the radiator work just fine? This is for a boosted 7thgen.
Old Aug 17, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
I would think it would be sufficient enough cooling because that 1/2 radiator is used to cool b16's, so now all you gotta worry about is getting it to mount securely.
Old Aug 17, 2005
C2i0v0i1C's Avatar
SuperMODrizd
check on the hose sizes and on the location of the overflow tank
Old Aug 17, 2005
turboengnr's Avatar
DONT PANIC
in order to fit my turbo, im building a custom aluminum 1/2 radiator. Ill let you know how it goes!
Old Aug 17, 2005
blouisgod's Avatar
Life Begins > 6800rpms
with a turbo and added heat, wouldn't you want to go to a large capacity radiator?
maybe not so much in phila i guess, but down here in Fl., im putting in a koyo rad before a turbo.
Old Aug 17, 2005
turboengnr's Avatar
DONT PANIC
if you have a high efficiency radiator, you shouldnt have to worry as much. If you use a radiator thats half the length, but twice the thickness (doesnt even need to be that thick) it should be fine.
Old Aug 18, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
It can only go so far however. The air is warmed up to a point where it cannot continue to cool the radiator after a certain thickness.
Old Aug 18, 2005
HondaLuver's Avatar
Its a celebration bitches!
alot of people that have turbos "upgrade" to a half size aftermarket... and most of them are getting over heating issues. and they eventually switch over to full size... go on honda-tech and look
Old Aug 18, 2005
turboengnr's Avatar
DONT PANIC
im simply speaking from experience. I have built several 1/2 sized radiators for turbocharged cars. I have never had a problem.
Maybe its the cores i use. I dont waste money on a cheap *** core. I use the highest efficiency core available.
this is true. But the honda core is very thin compared to others. doubling its thickness works very well.
The only reason i am going with a 1/2 core (which will be a little more than 1/2) is simply because if i dont, my turbo will not fit in my engine bay the way i want it to. I tried to squeeze an oversized turbo into the engine bay of my crx. One day I broke several motor mounts while at the track, which immediately pushed my turbo through my radiator. And it is never fun to be towed home from the track.
Old Aug 20, 2005
XxJDMCivicxX's Avatar
Don't forget alot of ppl running these half sized cores on honda-tech are running huge fmic blocking air and using insufficient fans(Stock fans). Half sized aftermarket rad w/ two pusher slim fan will cool just as effiecient as a full-size. Not saying full-size isn't better but some of the info is a lil bias.
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 3, 2015 04:33 PM
Islesfan
Sep 29, 2015 03:42 AM
anubis62
Sep 27, 2015 12:56 AM
260000milesgoal
Sep 25, 2015 07:41 PM
