head gasket
Old Aug 7, 2005
d17lpower03's Avatar
d17lpower03 is an unknown quantity at this point
head gasket
does anyone know where i can find a aftermarket headgaket for the d17??
already searched and all it says about headgakets was boost related stuff...just wanna let u know before yall say "Search"
thanks
Old Aug 7, 2005
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
none made yet that i know of....i had to buy a new one from honda for 70 bucks when i did my head swap.
Old Aug 8, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
http://www.7thgencivic.com/forums/sh...et+head+gasket
Old Aug 8, 2005
civic01vtec's Avatar
Nothing wrong with OEM
Old Aug 8, 2005
2K1Civic17"Gabe's Avatar
70's a ripoff. Honda wanted 32 bucks for a Nippon Leakless HG (oem)
Old Aug 8, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
majestic honda was 30.92 plus like 7 bucks s&h. 70 bucks, dude, you got beat.Go back to hat dealership and kick that guy in the nuts. I would strongly suggest buying arp headstuds, the d16z listing fits our cars fine. You are supposed to replace the factory fasteners any way and its not too much more for the headstuds. Nippon leakless HG is the only way to go IMO. We have run them on our cars and have had no problems. Blown headgaskets usually come from weak or stretched fasteners or poor tuning. Sometimes from overheating though too. The factory gasket for the d17 is a three layer steel gasket which is just fine for our motors.
Old Aug 8, 2005
jackburton's Avatar
^your running 12 psi daily right, i am curious, do you have head studs or is the methanol injection enough?
EDIT: got you mixed up with someone else, sorry, 9psi daily driver, whoops.
Anyway, have you had any problems with leaking HG, or does the methanol lower the temps enough where you do'nt?
NM about head studs read your profile.
Old Aug 8, 2005
HyaBoosta's Avatar
yeah just go nippon leakless and some arp and your good to go.
Old Aug 9, 2005
Does everybody know that Nippon Leakless is the OEM HG that honda sells? They dont make anything else, but the nippon. That is the brand that makes ours.
Just a heads up, so people dont search all over for one, when its OEM.
Old Aug 9, 2005
HyaBoosta's Avatar
there are two makers of oem headgaskets that honda uses and they have 2 different part numbers
370595 ISHINO GASKET
370596 NIPPON LEAKLESS
Head Gaskets
Old Aug 9, 2005
02fpcivic's Avatar
JackBurton are you asking me? If so Im running 8ish around town with no meth. I have headstuds with the oem gasket and my car runs off of an AEM EMS with dsm blue top injectors w/resistor box, y8 manifold w/d17 tb and idle control, and custom fuel system along with a KMS valvetrain and crower custom stage 3 turbo cam. Im playing it safe this time untill my lower end is finnished and ready to install. It prolly makes as much power on 8 as it made before on 11-12 so I dont wanna crank it up any more than that. So dont worry about that gasket if you get headstuds, worry about rod bolts stretching. I put d16 rod bolts in the stock D17 block for a safety as well. I had a problem with stretched rod bolts.
Old Aug 9, 2005
jackburton's Avatar
Thanks, i was asking.
Old Aug 9, 2005
02fpcivic's Avatar
yeah no prob dude. Honda OEM rocks!
Old Aug 10, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
My stock gasket bit the dust early. Fully tuned and was doing good for about 3 months. After pulling the head and buying another gasket this is what the shop in modesto ( Bell & Gains racing engines) SOld me.
Its a spray that you coat the headgasket with to give it alittle extra strenght. They use this on big block chevys. SO far its working pretty good.
Here is what the stock gasket looks like
Here is the spray that you use. Coat both sides of the gasket let it dry for about 10 minutes and then install.
Old Aug 10, 2005
Michalo187's Avatar
Abortion Survivor
Looks great
Old Aug 10, 2005
IDQcivic's Avatar
IDQcivic should not be trusted
Hey whats the part number for the ARP head studs for the D17A2, I know there was a post but now I can't find it, I'm trying to make a list of everything I need, thanks.
Old Aug 10, 2005
Jeff's Avatar
I was told it was this one. I would double check on this though. Someone sent me a link a while back.
http://www.nolimitmotorsport.com/prod/arp-208-4301
Old Aug 10, 2005
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
208-4301
honda d-16
10mm HSK
that is whats on the box.
cukaracha
30
Jul 26, 2015 12:01 PM
Ccoop87
Jul 9, 2015 03:26 PM
robbie374
Jul 7, 2015 02:56 AM
jdawgzcivic
Jun 30, 2015 06:35 PM
HondaHomer
May 14, 2015 12:24 PM
