Question about Pistons?
Old Aug 6, 2005
Michalo187's Avatar
Abortion Survivor
My friend has an older model civic and he bought some low compression pistons but before he had the chance to install his car was totalled. He offered to sell me his pistons but i was wondering if they will fit our cars. They are 75mm pistons and he says they will fit i was wondering if you guys had any idea about this. I hope they work this would be great for my turbo setup.
Old Aug 6, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
they may fit if they are for a d16. What you really need to do is order 1 d17 piston from honda, for which ever exact model yo may have,for example an EX/D17a2 would be PN 370680 at $28. Take that. and one of his pistons to a performance engine builder and have him measure it up. He should be able to give you an idea on if it will work. I know for a fact you can swap over to a whole d16 rotating assembly if you use a d16 oil pump so the low compression pistons might fit if the wrist pin diameter is the same.
Old Aug 6, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
they won't fit
Even a .0111 mm off, will throw it all out of wack.
Just get the right parts.
The parts are the cheapest step of building an engine,
Taking an engine appart and putting it together cost the most $$$$
You want to do it right the first time.
Old Aug 6, 2005
C2i0v0i1C's Avatar
SuperMODrizd
there will be some aspect of those older pistons that wont be right guarunteed
Old Aug 6, 2005
Michalo187's Avatar
Abortion Survivor
Well then what low compression piston options do i have? Cp for 700 Wiseco only know one member that has them. Arias and is there anymore? do you guys know the prices?
Old Aug 6, 2005
C2i0v0i1C's Avatar
SuperMODrizd
JE pistons, any of those places will make a custom order piston for u, u just have to know the specs and dimensions. sometimes they require a stock piston. which from the dealer is not that expensive last time i checked. two years ago. CP is a good brand, we got those for the WRX
Old Aug 6, 2005
supermex's Avatar
Piston part # XT- 519P76 Wiseco 76mm 9:01 compression about $450.00
Wiseco now makes 75mm pistons (stock size)
Call Race Engineering Tel: (561) 533- 5500 ask for Jonh if you call him, deffinately tell him I, Hector told you about them and he'll work you a discount also tell him about our 7thgencivic site.
Old Aug 6, 2005
IDQcivic's Avatar
IDQcivic should not be trusted
Would it be OK to put low compression pistons in before running turbo? I want to get low compression pistons and new rods and a new cam, then add the turbo so I can run more boost safely...
Old Aug 6, 2005
turboengnr's Avatar
DONT PANIC
just remember that by putting lower compression pistons and a turbo cam in when your not FI, the car will most likely have less power than stock.
naokigoffi
Aug 30, 2015 06:19 PM
totravska
Aug 30, 2015 12:02 AM
MamaBear2015
Aug 22, 2015 05:27 PM
martinsmartin
Aug 15, 2015 07:34 PM
Butterfli13
Aug 12, 2015 11:04 PM
