E-manage and nitrous ...
Old Aug 3, 2005
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
OK, so I'm curious... My built motor is finished and it goes in next Monday (pics WILL be taken!) but right now I am running the stock motor ... I have been running a Zex 75 shot for like 2 years now but I've never done anything to adjust timing with no ill effects (other than the blown head gasket which I attribute to Honda OEM head studs... Since I installed the ARP studs I have had zero issues and have been spraying since then ) ... I have been asked many times how big of a shot I could run on a built motor and my answer has always been 75 due to the timing issue ... Now, I have an emanage installed but all the settings on it are set to stock because I was waiting to boost before I started changing anything ... Since the Zex kit operates at WOT, can I simply retard the timing in emanage under the 100% throttle line of the timing map? I know that it isnt the best approach but I don't ever go to WOT unless I'm spraying anyways ... All this is pure speculation because all my money is going to turbo kit parts (thanks for the manifold Hwoody!) but I know there is a way to run a bigger shot than I'm currently running ... anybody wanna share thoughts on this??
I just can't wait for the new motor to go in, then I can't wait to be boosted ... any ideas or comments?
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ttamrekab
Sep 28, 2015 01:22 AM
Sep 27, 2015 11:33 AM
Michelle2006
Sep 19, 2015 06:09 AM
Dave Brabant
Sep 12, 2015 08:39 PM
