boost gauge problems..
Old Jul 31, 2005
Cocky's Avatar
Cocky guys kick ass!
which vac. line do i tap the boost gauge into and where is it located? thanks
Old Jul 31, 2005
turboengnr's Avatar
DONT PANIC
There is a small nipple on the side of the manifold that is capped off with a rubber plug. Take the plug off and use that.
Old Jul 31, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Just recently I asked same question, like 2-3 weeks back. I'm not going to find link now, but it should be easy. If you find it, you will get pics of where to find vacuum, fiel and "water" lines for turbo cooling. Good luck with turbo!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
C-Hamm
Sep 28, 2015 10:31 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
