Dyno tune done
Old Jul 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
Dyno tune done
Here was the final peak HP/torq = 169.8hp/154ft-lb's . Temp. out side was around mid 90 degrees and they only had one working fan on the car This was @ 7psi and take in to account that my car is auto trans
Old Jul 29, 2005
allmotor's Avatar
nor cal 7thgens
good numbers
Old Jul 29, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hmm, interesting ... how did they dyno your car if you have an auto?
other than that, good numbers ... what turbo kit?
I'm sure if you had a manual, cool weather, lighter/smaller wheels, bumped to 8 psi and removed your power steering (just for the run), you could pull 200 whp
Old Jul 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
This was in 2nd gear pull when they did a 2nd/D3 pull the shift from 2nd to 3rd was causing the tach pick up on the dyno to bounce arround. peak 3rd pull was 155hp. they did a total of 8 or 9 pulls as i recall. The kit is one i made. the wheels are 18's but pretty much as light as you can get.
Old Jul 29, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Good #'s for auto box! Congrats!
Whats up with a/f? Looks like a tad lean right to 4500 rpms.
I'm guessing what I will get with my TSI @ 8psi on my a2 with t25
Old Jul 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
This was a 2nd gear pull the 3rd gear pull showed much better AFR
Old Jul 30, 2005
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
The number is very impressive to me...when i had auto turbo, i dyno 150whp 150tq @ almost 8 psi.....but expect auto tranny to slip with that much power tho....at least that's waht happend to mine
Old Jul 30, 2005
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
sounds good, i had mine dyno tuned at 165hp @ 7psi, but i'm still having problems with that...
Old Jul 30, 2005
tfnaaf's Avatar
BLDNPSI Mod
did some street tunning today from 2500-4500 rpm's and got those AFR in line now maps to be posted shortly
Old Jul 31, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
exactly wat i was gonna say. ive only seen and heard auto's gettin only in the 140-150 range.
Leonhsieh: hrmm thats not a good thing for me. im hoping to go turbo sooner or later on my auto and dont want my tranny to slip. wonder if a tranny cooler would fix that.
Old Jul 31, 2005
tfnaaf's Avatar
BLDNPSI Mod
I've got a trans cooler installed, havent noticed any slipping yet
Old Jul 31, 2005
Michalo187's Avatar
Abortion Survivor
Good numbers my car only produced 160hp and 160 tq and its a manual but i plan on getting 200 on it when i fix everything up i am also going to take off my 18s for the dyno i don't know how much that can help
Old Jul 31, 2005
TheSmuggler's Avatar
I thought D3 would start your car in 1st then 2nd then 3rd, while "2" only keeps it in second gear... at least thats how it is in my car
Old Jul 31, 2005
tfnaaf's Avatar
BLDNPSI Mod
True, they would start it in 2nd then shift to D3 then take the picture for the 3rd gear pull
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
beanhead
Sep 24, 2015 12:04 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
