Help with BOV connect...
Old Jul 22, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Turbo kit is a very dicovering process
Befre install you think you know everything, then it turns out as you dont know small things...anyways my issue is:
My set up is - TSI extreme
I dont know how to connect right vacuum lines to BOV+Boost gauge+WG (internal)
This how I have it now: From vacuum hose I have splitter to connect 2 extra things - 1 connected one to BOV and second one to boost gauge.
Problem now: my boost gauge will read that I'm getting tooo much boost - 10-12 psi at 4500 or so...My bov is waay to loud - louder than exaust...
Q1: I'm correct with my vacuum lines set up?
Q2: Anything I have to connect to internal WG?
Q3: Do i need to adjust screws on BOV and/or on WG?
Help!
Old Jul 22, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Help!
It's very simple. Before I even go into this, I recommend a Vacuum Manifold. If you don't have one a Vacuum T will do.
Ok, if you don't have the WG hooked up to a Vac. source, it's not going to open up. So get another T, and run that T into the Vacuum and it should fix your problems. BTW don't run the car at that much boost, the outcome won't be very nice.
Old Jul 22, 2005
Hwoody77's Avatar
Help!
Ok if you take a look at This wastegate I am selling on eBay (Free Promo), you will see a VAC source still has to be hooked up to the WG, see that red line, that's the VAC line...
What kind of BOV do you have?
Old Jul 22, 2005
civic01vtec's Avatar
Do you have a seperate line from from your WG directly to your turbo ??
Old Jul 22, 2005
I understand thing about high boost, and this is what I'm trying to get rid of!
You are saying I need to tap T into WG line and run it to vacuum source line?
Old Jul 22, 2005
So I need to run a line from it to my vac source, right?
Old Jul 22, 2005
I did not pay atention to that one, I have regular T25 with internal WG.
Should it be there?
Old Jul 22, 2005
Should it be there?
There should be a nipple on the turbo and wastegate actuator. Connect a hose to each other.
Old Jul 22, 2005
like this .....
Old Jul 22, 2005
Ok, I will chack on that today after work...my torbo came preassembled with manifold and dounpipe flange attached...so I did not pay attention to naked nipples on the turbo...sexy
Old Jul 22, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Just get a vacuum manifold and throw away those T tap (they get confuse). I have like 4-5 T taps b4. It is better off getting a vacuum manifold. Looks a lot cleaner.
Old Jul 22, 2005
As I thought, its already connected.
Old Jul 22, 2005
This how I have it now: From vacuum hose I have splitter to connect 2 extra things: first connected to BOV and second one to boost gauge.
Anything I have to connect to internal WG? Anything extra?
Do i need to adjust screws on BOV and/or on WG? (higer ot lower settings?)
Old Jul 23, 2005
Hwoody77's Avatar
Bro, calm down and breathe. Everyone has answered your questions.
Your Vacuum lines up to that point are correct.
We all recommend a Vacuum Manifold.
The WG Vac. line should be going directly into your turbo.
I don't believe you can change your WG setting.
Old Jul 23, 2005
The rod that runs from the actuator to the downpipe is threaded and has a nut on it. Loosen the nut and disconnect the rod from the flapper on the downpipe. Turn the rod and to run more boost......shorten the rod, less boost.....make the rod longer. Reconnect to the downpipe and tighten the nut.
Old Jul 23, 2005
I have generic type BOV, one that comes with TSI kit.
What does the screw on BOV good for?
Old Jul 24, 2005
I figured out purpose of the screw - its to adjust sound volume for the BOV
Old Oct 30, 2005
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
like this .....
so you just use like a 3 inch hose and connect the WG to the turbo? no connection to the vacuum line?
Old Oct 31, 2005
tfnaaf's Avatar
BLDNPSI Mod
Yes, that is supposed to be the best way, but not all turbos have the nipple for a hose there
Old Oct 31, 2005
ya mines got one, i wasnt sure if it connected to that or the vacuum line...theres also another nipple on the charge pipe right before the throttlebody, i guess its incase u dont have the nipple on your turbo...should i just plug that?
Old Oct 31, 2005
tfnaaf's Avatar
BLDNPSI Mod
Yes, unless you have a reason to sense boost only just b4 the TB
Old Oct 31, 2005
ya i already hooked the WG up to that nipple on the turbo...but im seeing some people say EVERYTHING is hooked up to a vacuum line...including the WG.
Old Nov 1, 2005
ajhdragon's Avatar
7thgens official a$$hole
i agree with most of the people here. just get a vaccum manifold. thier fairly cheap. just tap the main vaccum into your brake booster vaccum. and then run everythign else to the vaccum manifold. real easy and clean to do.
Old Nov 1, 2005
tfnaaf's Avatar
BLDNPSI Mod
You CAN hook them all up to a central vacuum line like a vacuum manifold hooked in to the brake booster line if its easier. Thas how i and many others have done it.
Old Nov 1, 2005
well isnt it very different if u hook up the WG to a vacuum or a line under boost, how can u do one or the other??
Old Nov 1, 2005
v8eaterokv6's Avatar
i have a new home do u
i was wondering the same thing
Old Nov 3, 2005
ya theres no way you can do either-or.....i think it depends on the type of wastegate you have...if your turbo has a fitting on the end of it then im sure the internal wastegate that comes with it is not meant for vacuum.
JoeB16
Oct 21, 2003 05:26 PM
Boosted2k2
Engine Swaps
Sep 15, 2003 07:37 AM
iLLuMiNaTi
Engine Swaps
Sep 12, 2003 02:46 PM
Project2k2
Aug 21, 2003 06:23 PM
AzNciVic
Feb 11, 2003 11:21 PM
