Tsi Turbo Kit and Cel light on
Old Jul 20, 2005
morrmarr's Avatar
morrmarr is an unknown quantity at this point
Hello,
Just installed the tsi turbo kit on my honda civic 2001 lx. Works great. Still need to get it tuned. But since the "cel" light is on it was recommended that I get that checked first before tuning it. Is this true? Also do u guys think the "cel" light is on because the 2nd o2 sensor is just connected to the test pipe w/o a cat converter?
Thanks for your help!!
Old Jul 20, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I have similar proble, CEL will apper in 5 min of driving. Will go off if battery disconected.
I have no way cheking the reading on CEL, but with my idle issue, I thing its will be about running rich.
Old Jul 20, 2005
you more than likely need to get an O2 simulator.. i'm not turbo'd, but i think you do have to get one to get rid of the cel..
Old Jul 20, 2005
civic01vtec's Avatar
go to autozone, they check them for free
Old Jul 20, 2005
turboengnr's Avatar
DONT PANIC
get some sort of O2 sim. You can use electronic means, or mechanical means
Old Jul 20, 2005
No, we dont have Autozone in Canada.
Old Jul 20, 2005
TheSmuggler's Avatar
Well go to the nearest Canadian store, chances are they probably will
Old Jul 22, 2005
andyman97's Avatar
Turbo Guru
Buy an obdII scanner, it's under 100 bucks.
Old Jul 22, 2005
eye_see_you's Avatar
let the devil out
if your CEL is turning on that fast something is not right. My CEL with the TSI extreme kit only kicks on when i'm pushing really hard. Its normall the 2nd 02 sensor acting up then but it goes off on its own atleast it has for me
Old Jul 22, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Exclamation
I got one for 75 bones at autozone.
Old Jul 22, 2005
civicskater's Avatar
Chicks dig my scent
^^they had a deal around father's day one for $60, i should have got one lol
But yes, get an 02 sim or a CEL eliminator so you wont have to worry about that, and you do want to get it turned off before you tune because it'll throw your fuel/air maps into a mess that wont be good when boosting.
Old Jul 23, 2005
hk2ronin's Avatar
hk2ronin is an unknown quantity at this point
Ive heard the same info, u need an 02 simulator.
Old Aug 13, 2005
let the devil out
actually after some more work on my tsi extreme kit we found I was kickingthe cel because of a loose vaccum line
Old Aug 18, 2005
morrmarr's Avatar
Hello,
Thanks for all the info. Do appreciate it!! I found out why the CEL was on. My air temp. sensor was not connected. I just had the car tuned and runs great!!
Old Aug 19, 2005
2K1Civic17"Gabe's Avatar
nice^^ Glad you like it. TSI makes a nice kit with nice power, huh? I loved my kit. Its off the car as of today though. I drained my oil last night, so the last part to take off is my manifold (after my oil filter).
You will have a lot of fun with this kit, and blow some cars away that would never expect it. What numbers did you make??
Peace
Old Aug 19, 2005
aellerman's Avatar
aellerman is an unknown quantity at this point
my CEL light has been on since the day i was boosted... car runs great though, no idling issues or anything...it's on all the time.. when i start the car till i turn it off...
Old Aug 19, 2005
and yes, it is DEFINATELY the reason the CEL is on. Either get a hi flow cat and weld a bung after it, or get a MIL eliminator. Either one will work. I recommend the cat, but thats just me wanting to be legal.
Supramk3
May 11, 2015 07:55 PM
mikevtec
May 3, 2015 01:36 PM
cloudguy
Apr 28, 2015 05:02 AM
Boosted
Nov 21, 2003 11:03 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
