Tsi turbo question
Old Jul 18, 2005
morrmarr's Avatar
morrmarr is an unknown quantity at this point
Tsi turbo question
Hello,
I just installed the tsi turbo and it runs great. Had one question. The check engine light turned on? Did any one of u experience the same thing when u installed the kit? If so, what did u do to fix the problem? I know this question has been asked probably hundrends of times but is it okay to drive the car with the "check engine" light on?
Thanks for your help in advance!!
Old Jul 18, 2005
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
It may Vary.. 1st off what kinda fuel Setup are you running?
2nd Have you checked what kinda code is throwing... Like MISFIRE cylinder 1,2,3 or 4.
Or something of that Nature..
what kinda exahust pipin did you use? ( DO YOU STILL HAVE YOU'R CAT)
Did you keep the Exahust Temp Pressure that was down there.? or you disconected it?
Old Jul 18, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
go to autzone / adv auto have have them scan the code.
Old Jul 18, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I have CEL on as well.
To check the code of it...mmm...cant you do it yuorself?
Old Jul 18, 2005
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
could i use your installation manual??
Old Jul 18, 2005
2K1Civic17"Gabe's Avatar
could be that the MAP Box (little black box) is not hooked up, or hooked up correctly. It could be that you used their settings, ran hella lean, and blew a HG or something else. Did you get it tuned? Is the CEL on all the time, or only under boost? What are you using for fuel?
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
